Author Topic: xgui not showing any settings  (Read 7942 times)
Offline scorpionz
« on: August 12, 2011, 01:16:44 pm »
I've combed through the forums, checked all my settings, followed procedures as best as I could to resolve problems but still cannot figure out what is wrong..
The problem I am facing is that the xgui will not show any of the server settings. Group lists does not show any players, ban list does not show any bans that are in place, checks for settings are all unticked..
I am set as the server owner will full permissions, the setting files on the server are not blank or altered. I am able to manually change settings through console commands..
I am running the latest version of ulx/ulib/xgui/apromote, I am at a loss to what could have happened.
Re: xgui not showing any settings
« Reply #1 on: August 12, 2011, 01:26:56 pm »
It will help the ULX team find a fix for your problem much faster if you include a start-up log.
Offline scorpionz
« Reply #2 on: August 12, 2011, 01:33:01 pm »
Ok, let me try to get that for you.. Also, i noticed that when the xgui updates, an error message of this shows.. XGUI: Command getVetoState not recognized!
Offline scorpionz
« Reply #3 on: August 12, 2011, 01:42:40 pm »
Mounting hl2.. OK
Mounting cstrike.. OK
Mounting dod.. Not downloaded fully? Try playing it first.
Mounting ep2.. OK
Mounting tf.. OK
Mounting episodic.. OK
Mounting hl2mp.. OK
Mounting portal.. OK
Mounting lostcoast.. Not downloaded fully? Try playing it first.
Mounting hl1.. Not downloaded fully? Try playing it first.
Mounting hl1mp.. Not downloaded fully? Try playing it first.
Mounting zeno_clash.. Not downloaded fully? Try playing it first.
Mounting left4dead2.. Not downloaded fully? Try playing it first.
Mounting left4dead.. Not downloaded fully? Try playing it first.
Mounting diprip.. OK
Mounting zps.. Not downloaded fully? Try playing it first.
Mounting pvkii.. Not downloaded fully? Try playing it first.
Mounting dystopia.. Not downloaded fully? Try playing it first.
Mounting ageofchivalry.. Not downloaded fully? Try playing it first.
Garry's Mod server.dll Build #125 [Jun 25 2011 19:58:09]
maxplayers set to 10
Unknown command "sv_allow_wait_command"
Unknown command "sv_AdvDupeEnablePublicFolder"
Unknown command "sbox_maxwire_wheels"
Unknown command "sbox_maxwire_waypoints"
Unknown command "sbox_maxwire_values"
Unknown command "sbox_maxwire_twoway_radioes"
Unknown command "sbox_maxwire_turrets"
Unknown command "sbox_maxwire_thrusters"
Unknown command "sbox_maxwire_target_finders"
Unknown command "sbox_maxwire_speedometers"
Unknown command "sbox_maxwire_emitters"
Unknown command "sbox_maxwire_simple_explosive"
Unknown command "sbox_maxwire_sensors"
Unknown command "sbox_maxwire_screens"
Unknown command "sbox_maxwire_relays"
Unknown command "sbox_maxwire_rangers"
Unknown command "sbox_maxwire_radioes"
Unknown command "sbox_maxwire_sockets"
Unknown command "sbox_maxwire_plugs"
Unknown command "sbox_maxwire_pixels"
Unknown command "sbox_maxwire_panels"
Unknown command "sbox_maxwire_outputs"
Unknown command "sbox_maxwire_oscilloscopes"
Unknown command "sbox_maxwire_locators"
Unknown command "sbox_maxwire_lights"
Unknown command "sbox_maxwire_inputs"
Unknown command "sbox_maxwire_indicators"
Unknown command "sbox_maxwire_hoverballs"
Unknown command "sbox_maxwire_gyroscopes"
Unknown command "sbox_maxwire_gpss"
Unknown command "sbox_maxwire_gate_trigs"
Unknown command "sbox_maxwire_gate_times"
Unknown command "sbox_maxwire_gate_selections"
Unknown command "sbox_maxwire_gate_memorys"
Unknown command "sbox_maxwire_gate_logics"
Unknown command "sbox_maxwire_gate_comparisons"
Unknown command "sbox_maxwire_gates"
Unknown command "sbox_maxwire_explosive"
Unknown command "sbox_maxwire_dual_inputs"
Unknown command "sbox_maxwire_detonators"
Unknown command "sbox_maxwire_buttons"
Unknown command "sbox_maxwire_adv_inputs"
Network: IP 64.31.27.182, mode MP, dedicated Yes, ports 27015 SV / 27005 CL
Lua initialized (Lua 5.1)
Simple Prop Protection Version 1.5 by Spacetech has loaded
[addons\steeringwheelpack\lua\autorun\steeringwheelpack.lua:1] ')' expected near '.'
//  shared/datastream.lua    //
//  server/upgrade.lua       //
//  shared/hook.lua          //
[ULIB] Loading SHARED module: aafk.lua
//  sh_base.lua              //
//  MODULE: uteam.lua        //
//  MODULE: xgui_server.lua  //
// ULX GUI -- by Stickly Man //
// Adding Main Modules..     //
//  bans.lua                 //
//  commands.lua             //
//  groups.lua               //
//  maps.lua                 //
//  settings.lua             //
// Adding Setting Modules..  //
//  cl_apromote.lua          //
//  client.lua               //
//  server.lua               //
// Adding Gamemode Modules.. //
//  sandbox.lua              //
// Loading Server Modules..  //
//  sv_apromote.lua          //
//  sv_bans.lua              //
//  sv_groups.lua            //
//  sv_maps.lua              //
//  sv_sandbox.lua           //
//  sv_settings.lua          //
// XGUI modules added!       //
WireMod Installed. Version: 2459
ERROR! Module 'zlib_b64' not found!
ScriptEnforce is disabled
Skipping E2 extension 'holoanim'.
Skipping E2 extension 'tracesystem'.
Compressing lua files into data pack..
Skipped. Datapack exists.
Executing dedicated server config file
Couldn't find scene 'scenes/npc/vortigaunt/vort_vort_chant21.vcd'
Couldn't find scene 'scenes/npc/vortigaunt/vort_vort_chant05.vcd'
Couldn't find scene 'scenes/npc/vortigaunt/vort_vort_mant04.vcd'
Couldn't find scene 'scenes/npc/vortigaunt/vort_vort_livetoserve.vcd'
Couldn't find scene 'scenes/npc/female01/gordead_ques03a.vcd'
Couldn't find scene 'scenes/npc/female01/gordead_ques03b.vcd'
Couldn't find scene 'scenes/npc/female01/nice.vcd'
Couldn't find scene 'scenes/npc/male01/nice01.vcd'
Couldn't find scene 'scenes/npc/male01/nice02.vcd'
Couldn't find scene 'scenes/npc/female01/oneforme.vcd'
Couldn't find scene 'scenes/episode_1/npc/female01/cit_kill19.vcd'
Couldn't find scene 'scenes/episode_1/npc/female01/cit_kill20.vcd'
Couldn't find scene 'scenes/episode_1/npc/male01/cit_buddykilled14.vcd'
Couldn't find scene 'scenes/episode_1/npc/male01/cit_buddykilled15.vcd'
Writing cfg/banned_user.cfg.
Client "TR Cpl. Bird Man" connected (66.41.68.159:27005).
Client "jaymorlot" connected (74.89.226.255:27005).
ERROR: Hook 'XGUI_InitServer' Failed: [@lua\includes\modules\glon.lua:349] Unknown type ID, 0!
Removing Hook 'XGUI_InitServer'
Connection to Steam servers successful.
   VAC secure mode is activated.
Client "Granger" connected (71.34.37.136:27005).
Client "ק๏ק10קคllє" connected (80.162.12.249:27005).
Client "scorpionz" connected (69.59.43.153:27006).
Simple Prop Protection: 294 props belong to world
ConCommand blocked! (SPropProtection_toggle 1
Error Vertex File for 'Alyx.mdl' checksum -191986205 should be 1125430304
Dropped Granger from server (Disconnect by user.)
Timer Error: Tried to use a NULL entity!
Error Vertex File for 'Humans\Group03\male_09.mdl' checksum -1185842804 should be -238698339
Timer Error: [@addons\sui_scoreboard_modified_v2\lua\sui_scoreboard\rating.lua:44] Tried to use a NULL entity!
Eww, the xgui is not hooking?
Offline scorpionz
« Reply #4 on: August 12, 2011, 02:11:00 pm »
It was working fine two days ago, I never made any changes to anything, this just happened out of the blue. The xgui does not respond to any changes. Server restart does not fix it. APromote stopped working.
Offline scorpionz
« Reply #5 on: August 12, 2011, 02:32:19 pm »
Well, I figured out the problem. The APromote settings file got corrupted somehow, I replaced it and xgui is no longer fubar'd.. I find it strange that the settings file for that addon is not of standard format. The creator should fix this, I suppose..
« Reply #6 on: August 12, 2011, 04:58:38 pm »
Hmm, interesting. I can have a quick chat with the maker of APromote as to what may have caused the issue, but it's definitely XGUI's fault that a broken addon prevented everything from working. (And it should be relatively easy to fix, too)
