General
Off-Topic
Minecraft 1.8 server
Topic: Minecraft 1.8 server (Read 5905 times)
killforfun
Jr. Member
September 12, 2011, 12:45:03 pm »
Im broad and i cant find anyone to play with :C
Want to play
server ip: amc.chrome-servers.net
skype: ronnie.reiff or ronnie reiff
you will need the 1.8 patch to join I belive
MrPresident
Ulysses Team Member
Re: Minecraft 1.8 server
September 12, 2011, 01:44:47 pm »
I tried to run a 1.8 server on my dedicated server as well. It is so littered with bugs at the moment that it is almost not even worth playing SMP until it is properly released.
killforfun
Jr. Member
Reply #2 on:
September 12, 2011, 03:08:57 pm »
Yeah there are a lot of bugs but the new landscapes that are generated are amazing and i am only letting a max of 4 people
also if you crash a lot its because you need the right java installed if you have 32 bit install 32bit if you have 64 bit install 64 bit
Megiddo
Ulysses Team Member
Project Lead
Reply #3 on:
September 12, 2011, 03:12:35 pm »
The experience orb problem is the most annoying bug. I just setup a lava pit near the spawn and told people to jump in from time to time.
MrPresident
Ulysses Team Member
Reply #4 on:
September 12, 2011, 07:14:17 pm »
The orbs is a quick and easy fix. This class file modification simply removes them for the time being as they are useless right now anyway.
http://www.minecraftforum.net/topic/621323-patch-exp-orbs/
Megiddo
Ulysses Team Member
Project Lead
Reply #5 on:
September 12, 2011, 07:42:53 pm »
That does the trick, thanks Mr. P
General
Off-Topic
