Author Topic: Server Crashes | ULX and ULIB When Added  (Read 13184 times)
Offline Bite That Apple
  • Apple Innovations 2010®
    • Fun 4 Everyone Gaming
« on: October 22, 2011, 04:10:21 pm »
Well, I've had ULX and ULIB for a long time now way before they has XGUI involved in it. I know how to use ULX and ULIB very well and I'm no noob with it. I turned off my server about 2 weeks ago for some reasons then turned it on today, I had to update the server cause It needed an update. So I updated the server then turned it on all of the sudden it crashed about 4 or 5 seconds after starting it up. So I thought some addon is conflicting with Garrysmod so I moved all the addons out of the addons folder and started it up, Garrysmod started up fine so I started to add the addons one by one. Once they all passed I finally got to ULX & ULIB so I was like well this should pass it must be Wire Mod. Then when I started it with ULX and ULIB added it crashed about 3-4 seconds after I started the server, I was like WTF. Then I removed everything inside of ULX and ULIB except the main folder and redownloaded it with SVN. Tried it again and it failed, Removed the whole folder and redownloaded it from ulyssesmod.net. Started it again failed, So then I removed everything in the addons folder (not including the default thing that came inside the folder like dod, tf, portal, ect) started it again and FAILED. so then I became mad I deleted everything and redownload the garrysmod started it back up with ULX and ULIB and still failed. So now I have no clue what to do and I'm not making this topic. Also because I have not played and Steam games for a while now I might be late or you may already know this problem... So Sorry If this is just wasting your time.
Re: Server Crashes | ULX and ULIB When Added
« Reply #1 on: October 22, 2011, 04:27:10 pm »
Not wasting our time. Just too many variables with not enough detail.
First, turn on console logging in your server.cfg (use google to learn how).
WHen it crashes, give us what it spit out before doing so.
Attach it to your next post.
You may also try backing up then removing your /data/ulx and /data/ULib folders before starting your server.
If you've been using an older version, one of the files may have gotten corrupt.
« Reply #2 on: October 22, 2011, 06:09:53 pm »
I did removed all ULX and ULIB files in the data folder.
Sorry for the delay... Anyways
I can't log it cause it crashes before it can create the log, Unless im doing it wrong.
*I'm really sorry if you cant do anything with what I have done, I really dont know what to do.*
[Here's a video]
http://www.youtube.com/watch?v=Way4ODDeyUE
[Here's a Screenshot]
http://fun4everyones.info/index/ULX/VIDEO/PIC/SCRN22.png
« Reply #3 on: October 22, 2011, 07:15:08 pm »
Chaos, Gmod updated Oct 14. It broke ULX/ULib 'release' version.
We then fixed SVN...our beta code. It worked. Gmod then again updated Oct 17 and may have rolled back what broke ULX.
However, I'm not sure what you're problem is.
No one so far has reported ULX 'SVN' version broken.
Make sure you're getting both ULib and ULX SVN, and putting them in separate folders within your addons.
Hoping someone else has an idea, as I sure don't
« Last Edit: October 22, 2011, 08:13:31 pm by JamminR »
« Reply #4 on: October 22, 2011, 09:27:33 pm »
I'll try again tomorrow, but everything was deleted and redownloaded, I even deleted the cl & sv Data Base Files just to make sure if ULX was using any Database files that they were deleted.
« Reply #5 on: October 23, 2011, 12:06:03 pm »
Hmm, that is odd. The errors in that screenshot aren't related to ULX at all, not even lua. Is it possible for you to get the entire console output by stopping it from closing or seeing if you can highlight text in the console window before it closes?
Otherwise, I'm also baffled. I just updated my local gmod srcds server with the latest ULX and ULib SVN and it ran just fine :-\
When you said you deleted everything, did you really delete everything? The entire scrds installation and garrysmod and any server configuration files? Perhaps there's something in server_config.cfg that's causing issues? I really am not sure :-\
« Reply #6 on: October 23, 2011, 02:41:45 pm »
When I said I deleted everything I really meant everything, The whole Orangebox folder, Nothing was saved. BUT when I was redownloading all of the games again It choose to place counter strike source in a different place. Instead of calling it CStrike it called it CSS (And Yes I Know What That Stands For) It didn't place it in the Orangebox it placed it in the directory behind the Orangebox, This might not be useful information though. Anyways everything was deleted, Then after everything was done downloading I went to ulyssesmod.net then clicked 'Download' then I copied and paste the links for the SVN download and it began downloading. After that was all finished I placed it inside of the Addons started the server then I get this bullshit again ONLY WHEN ADDING ULX and ULIB. If I remove those files the server starts fine with no crashing or problems.
I can't log anything else because it moves way to fast so I can't screenshot it log it or anything the first 10 or 15 lines are like mounting the games then says my default ip and it goes down just a little more and dies.
Also I learned that if I only add ulx it works fine, Its just ulib. If anyone has any suggestions please reply on this Topic, Email Me, Or when can Team Viewer if anyone has Team Viewer.
« Reply #7 on: October 23, 2011, 04:19:25 pm »
Your srcds watch cmd file....what command lines are you using to start your server (paste into 'code' bb tag, XXXing any passwords)
Only suggesion I'd have at this time, since it's rumored Garry reverted changes that required us to fix an update he broke, and that code is still in SVN, is try our release version of both ULX and ULib.
Delete your addons/ULib and addons/ulx
Backup, then delete, your /data/ULib and /data/ulx folders.
Download, extract, the non-svn zip file versions of both ULib and ULX to your addons folder from our downloads page.
Start server up again. Give results.
What concerns me, and my team, is the oddity that SVN is still working for everyone else that updated it, even after reversion by Garry.
Please confirm, and I know you've typed much info.
After re-install of the srcds server and game content, as part of your testing, the only non-original content/addons you've attempted placing back in the appropriate folders are ULib and ULX.
You did not place any of your /cfg files back.
You did not place any of your /data/U... folders back.
I'm talking vanilla server, minus even your previous bans/configs, except for non-modified-by you Ulib and ULX?
« Reply #8 on: October 23, 2011, 04:27:11 pm »
@echo off
cd C:\srcds\orangebox
echo Starting game server
echo Beginning "Garry's Mod"
echo *************************************************************************************************************************************************************
srcds.exe -console -nocrashdialog -game garrysmod +port 27016 +fps_max 300 +map gm_construct +sv_defaultgamemode Sandbox +maxplayers 14 -tickrate 66
echo Your First "Garry's Mod" Server Has Now Started!
echo It is recommended that you start Server Crash Recovery aswell.
@echo off
cls
echo Protecting srcds from crashes...
echo If you want to close srcds, close the srcds window and type Y depending on your language followed by Enter.
title Server Watchdog Working
:srcds
echo (%time%) srcds started.
start /wait srcds.exe -console -nocrashdialog -game garrysmod +port 27016 +fps_max 300 +map gm_construct sv_defaultgamemode Sandbox +maxplayers 14 -tickrate 66
echo (%time%) WARNING: srcds closed or crashed, restarting.
goto srcds
Also the Zip works fine.
« Reply #9 on: October 23, 2011, 04:33:51 pm »
So The Zip Works Fine
The SVN Fails.
« Reply #10 on: October 23, 2011, 04:42:26 pm »
Wait nvm They both just dont work  :'(
« Reply #11 on: October 23, 2011, 04:46:44 pm »
Try removing "-nocrashdialog" from the cmd file
« Reply #12 on: October 23, 2011, 05:03:16 pm »
No Luck  :(
« Reply #13 on: October 25, 2011, 07:09:30 pm »
I Don't Know What To Do :(. Can I have one of your guys ULX and ULIB maybe?
« Reply #14 on: November 05, 2011, 09:12:35 pm »
Unfortunately that wont work, because through SVN, all version remain updated and all versions downloaded are the same. I think its a server error, not a ULX error.
