Author Topic: Help about IP.  (Read 6956 times)
Offline betoche12345
Help about IP.
« on: November 12, 2011, 12:57:13 pm »
How Do I see someone's IP when they join my server or block them by IP?
Thanks
EDIT:
Also What is differ with ULX and ULIB?
« Last Edit: November 12, 2011, 01:00:30 pm by betoche12345 »
Re: Help about IP.
« Reply #1 on: November 12, 2011, 04:13:17 pm »
ULib is a library that provides extra functions and utility to coders for Garry's Mod.
ULX is an administration mod. It uses ULib, but the two are separate.
Also, if you wish to find someone's IP address type 'status' in your console. this will return everyone's IP / SteamID / UID / etc etc etc.
To ban an IP address I believe the command is addip <ip address> if you type in addip and hit enter it should tell you what else is required to use the command.
 I would recommend banning by STEAMID though as IP address often change frequently.
Re: Help about IP.
« Reply #2 on: November 12, 2011, 05:42:53 pm »
You have to type it in your server's console.  Just thought I'd let you know.  You can also find the IP addresses of people in your ulx logs.  (<gmod root>/data/ulx_logs)
