Author Topic: Area Admin  (Read 6211 times)
Offline Hybris
Area Admin
« on: December 15, 2011, 11:59:30 am »
Is it possiple to make a tool or command for target an area where the owner of the target area is in control of everything even other players?
Re: Area Admin
« Reply #1 on: December 15, 2011, 01:42:57 pm »
Interesting idea.
Possible Logic flow; (No, i won't be working on this)
If ply is in cube coordinates set by admin tool then
If ply is owner of area then
get/store current ply access
raise access in memory only (don't want them to leave/rejoin server as new high access
Now, as for how/when to check the players coordinates in relation to the area, in my mind, thats when it starts getting complicated and optimization required.
Offline Hybris
Re: Area Admin
« Reply #2 on: December 15, 2011, 02:28:46 pm »
Could it be something opposite jail?
Re: Area Admin
« Reply #3 on: December 19, 2011, 05:47:40 pm »
If you mean "ulx jail", then you're not going to be able to use the code from that in this idea, as they're accomplishing totally different things.
JamminR has the right idea to get someone started on coding this. :)
Offline Hybris
Re: Area Admin
« Reply #4 on: December 19, 2011, 06:08:16 pm »
That sound great :)
