Author Topic: Ulx Menu error  (Read 9753 times)
Offline Own3r
Ulx Menu error
« on: December 19, 2011, 02:30:47 pm »
Recently ULX has broken for me, I've tryed deleting everything related to ULX/Ulib from my Garry's Mod folder and re-installing and nothing seems to work. When I start my server up I get a number of errors:
http://imageshack.us/photo/my-images/839/2011121900001.jpg/
http://imageshack.us/photo/my-images/830/2011121900002.jpg/
The console command 'ulx menu' doesn't work:
http://imageshack.us/photo/my-images/534/2011121900003z.jpg/
and neither does !menu
The only way I can get the menu up is by using XGUI command, in which I get this error:
http://imageshack.us/photo/my-images/805/2011121900005.jpg/
and then the menu doesn't have any groups and some other things are broken.
http://imageshack.us/photo/my-images/854/2011121900006.jpg/
I would really appreciate some help here. Excuse me if I've been a complete idiot and missed something obvious.
Thanks in advance
Own3r
Re: Ulx Menu error
« Reply #1 on: December 19, 2011, 03:16:33 pm »
Can we see the console output for the server? If it's a listen server, then you should just need to scroll up and post the output above what you have in your images.
Re: Ulx Menu error
« Reply #2 on: December 19, 2011, 05:37:32 pm »
Odd, I would like to see the output from further back as well.
Offline Own3r
Re: Ulx Menu error
« Reply #3 on: December 20, 2011, 05:48:24 am »
http://imageshack.us/g/522/2011122000001.jpg/
Above the first one is just some caches being deleted and the third goes down to the other two I provided.
Hope this helps, and yes it is a listen server. I just opened my ports etc.
Re: Ulx Menu error
« Reply #4 on: December 20, 2011, 08:18:44 am »
Re: Ulx Menu error
« Reply #5 on: December 20, 2011, 03:03:41 pm »
I'm thinking that some rogue addon is overwriting your file I/O library, so I'd be interested to hear if ULX and ULib work with no other addons installed as well.
Offline EliteOps12
  • Apache Gaming owner
    • Apache Gaming
Re: Ulx Menu error
« Reply #6 on: December 21, 2011, 04:06:42 pm »
I think that it is simply a bug with KeyValues string, perhaps caused by an overload of data.
Offline Badshar
Re: Ulx Menu error
« Reply #7 on: December 22, 2011, 04:01:43 am »
I'm having the same problem :(
And i've tried everything, including removing all of the other addons and reinstalling the server.
Yes, it is a updated ulx/ulib install from the website, i also deleted the ulx and ulib data folders...
Whats strange is when the server is running it still gives me all of the adverts and admin permissions as it did when it was functional, only now it will not load the settings and says that there was a fatal error and it cannot connect to the server... We can still kick, cloak, ban, etc... its mostly the config settings not loading... people using "!"
 I've never had any problems with ulx before...
I'm seriously stuck...
Help?
