Author Topic: Questions about map changes  (Read 4780 times)
Offline RT_Charger_69
« on: December 26, 2011, 03:11:10 pm »
I am new to the new gui for ulx. I just updated today, because the old ulx that I had (I think it was 3.42) could not recognize any of the maps on the server in the maps section.
After the update, the only option that I have under the maps section is votemap. I want to be able to force change the map, but the option is grayed out. How do I 'ungray' this option?
Also, when I tried to vote to a different map, It said that I cannot change until 10 min after the previous change. Is there a way that I can take out this time limit?
One more thing, when I went into the server settings in the gui, I tried to disable the votemap feature. I received a message that said I didn't have permission to change the cvar. I am superadmin on the server. How can I fix this?
Thanks for the help!
Re: Questions about map changes
« Reply #1 on: December 26, 2011, 07:23:57 pm »
hmm, seems like ULX is not recognizing you as a Superadmin, get into rcon, and then type the following "ulx adduser RT_Charger_69 superadmin".
« Reply #2 on: December 26, 2011, 09:05:23 pm »
Yeah, something was messed up, so I deleted anything ulx or ulib related from the settings and data folders in the gmod root, and ran the server once to recreate those files and folders. Then I placed a copy of my users file back into the settings folder.
Now everything works.
Thanks for the suggestion.
« Reply #3 on: December 27, 2011, 10:34:16 am »
Thanks Hellfox
This setting can be changed on the "Settings"->"Server" tab, under votemap options I believe. This is however for other players on your server to vote on maps, not for the admins, so you may be fine with leaving it alone.
