ULX XGUI OFFLINE THING!
Topic: ULX XGUI OFFLINE THING! (Read 5631 times)
timp11
December 31, 2011, 06:12:59 pm »
When i try to go into the admin menu it says its not installed or not started :S and it goes in offline mode...
Like this one
/index.php/topic,5483.0.html />
Can you please help me with how i shal fix that? Thx
Megiddo
Ulysses Team Member
Project Lead
Re: ULX XGUI OFFLINE THING!
December 31, 2011, 10:20:39 pm »
Three things (do them in order, please
1. Share your server and client console logs with us.
2. Run "ulx debuginfo" in the server console and share the results with us.
3. Contact me on Steam tomorrow (username MegTech) and we'll do whatever we can to help.
Last Edit: December 31, 2011, 10:25:53 pm by Megiddo
timp11
Reply #2 on:
January 01, 2012, 07:58:37 am »
16:57:58 L 01/01/2012 - 16:58:03: Lua Error: [@addons\ulx\lua\ulx\modules\sh\util.lua:259] bad argument #1 to 'KeyValuesToTable' (string expected, got no value)
16:57:58 [@addons\ulx\lua\ulx\modules\sh\util.lua:259] bad argument #1 to 'KeyValuesToTable' (string expected, got no value)
Megiddo
Ulysses Team Member
Project Lead
Reply #3 on:
January 01, 2012, 09:25:56 am »
Please contact me on Steam
Megiddo
Ulysses Team Member
Project Lead
Reply #4 on:
January 01, 2012, 10:02:18 am »
To continue our conversation timp11 (since I forgot you were offline on Steam...):
Run the SVN version of ULX and ULib and let me know if it fixes your issue. Looks like Garry never actually reverted his file I/O breakage after all, but SVN has the changes necessary.
Also, please change your RCON password since I now know it.
timp11
Reply #5 on:
January 01, 2012, 10:07:47 am »
i have used svn -.- i have allways used svn of those! but the xgui says it is offline thing :S
JamminR
Ulysses Team Member
Sertafide Ulysses Jenius
Reply #6 on:
January 01, 2012, 10:14:23 am »
Totally off the wall question to current Meg/Timp conversation, but I've seen oddities due to PAC before.
Timp, you're not running the PAC addon by any chance are you?
If so, remove it from your client and server, see if that helps anything.
Megiddo
Ulysses Team Member
Project Lead
Reply #7 on:
January 01, 2012, 10:19:30 am »
timp, if you were using the latest SVN revision you shouldn't be having the trouble you're having... please double check that you're using the latest svn.
