Author Topic: Possible to add new columns to an existing SQL table?  (Read 6396 times)
Offline DeimosTK
« on: January 10, 2012, 06:33:33 pm »
I just started learning Lua/SQL a few days ago and pestered Megiddo with some questions, so I thought I'd give him a break and ask for help here.
I'm trying to set up a function that allows me to add new columns to an existing SQL table. Is this possible?
This is the non-functioning code I have thus far. It runs when a player joins the server, but I just realized it would probably be more efficient if it ran only once when the server booted up, so I'll have to modify it to do that.
sv_serverflags.lua
-- Create the SQL table if it doesn't exist
if not sql.TableExists( "server_flags" ) then
    sql.Query( "CREATE TABLE IF NOT EXISTS server_flags ( id INTEGER NOT NULL PRIMARY KEY AUTOINCREMENT, player INTEGER NOT NULL, initialflag INTEGER NOT NULL );" )
-- Set up the flags
local ServerFlags = {
"testflag1",
"testflag2",
"another_flag"
-- Add flags to the player if they don't already have them when they join the server
function FlagSetup( ply )
    local uid = ply:UniqueID()
    -- Make sure the player has a row in the table - blatantly plagiarized from UTime
    local row = sql.QueryRow( "SELECT initialflag FROM server_flags WHERE player = " .. uid .. ";" )
    if not row then
        sql.Query( "INSERT into server_flags ( player, initialflag ) VALUES ( " .. uid .. ", " .. 1 .. " );" )
    -- Cycle through the list of flags
    for k,v in pairs(ServerFlags) do
        local currentflag = sql.Query("SELECT " .. ServerFlags[k] .. " FROM server_flags WHERE player = " .. uid .. ";")
        -- If the player doesn't have this flag in their row in the SQL db, add it
        if not currentflag then
            -- Add the column
            sql.Query("ALTER TABLE server_flags ADD " .. Flags[k] .. " INTEGER NOT NULL WHERE player = " .. uid .. ";")
            -- Make the flag value "0" (Hope this doesn't make everyone's Flag[k] value "0"...)
            sql.Query("INSERT into server_flags (" .. Flags[k] .. ") VALUES (" .. 0 .. ");")
hook.Add( "PlayerInitialSpawn", "FlagSetup", FlagSetup)
I have pretty much no idea what I'm doing when it comes to SQL, so don't be afraid to treat me like a child in your explanation.
EDIT: Realized I forgot to assign "player" a value in the table, that would definitely be a problem. Added that fix.
« Last Edit: January 10, 2012, 11:05:08 pm by DeimosTK »
Re: Possible to add new columns to an existing SQL table?
« Reply #1 on: January 11, 2012, 12:05:25 am »
When doing ANYTHING related to coding (web in particular) use this website. It will be your best friend.
http://www.w3schools.com/
the SQL query you are looking for to add a column to an existing SQL table is as follows:
ALTER TABLE table_name ADD column_name datatype
datatypes can be found Here
« Reply #2 on: January 11, 2012, 12:07:50 am »
Oh, read your code a little...
you would not need the WHERE portion of this query. You are adding a column to the table, you don't need to define a place to add it within the table.
Offline DeimosTK
« Reply #3 on: January 11, 2012, 12:17:56 am »
Yeah, I finally got the code to work due to correcting that error, as well as becoming aware of the fact that ALTER TABLE doesn't seem to like INTEGER NOT NULL, whereas regular INTEGER worked. I also replaced INSERT with UPDATE. I appreciate the help, and I've been referring to that w3schools link a lot lately.
It's now as follows:
-- Flags
local Flags= {
"testflag1",
"testflag2",
"another_flag"
function ServerFlags( ply )
    if not row then
    for k,v in pairs(Flags) do
        local flag = sql.Query("SELECT " .. Flags[k] .. " FROM server_flags WHERE player = " .. uid .. ";")
        if not flag then
            -- Add the column
            sql.Query("ALTER TABLE server_flags ADD " .. Flags[k] .. " INTEGER;")
            -- Give the flag a value
            sql.Query( "UPDATE server_flags SET " .. Flags[k] .. " = " .. 0 .. " WHERE player = " .. ply:UniqueID() .. ";" )
hook.Add( "PlayerInitialSpawn", "ServerFlags", ServerFlags)
« Last Edit: January 11, 2012, 12:20:19 am by DeimosTK »
« Reply #4 on: January 11, 2012, 09:31:31 am »
Good deal, glad I could be of help.
w3schools is an amazing resource, you should be sure to use it. You will learn a LOT.
