Author Topic: I cant make myself an admin to my server!  (Read 17963 times)
Offline Seaxneat
« on: January 19, 2012, 09:53:43 am »
How do I log onto the server as the admin or owner? I am trying to use ulx. I followed the tutorial for adding yourself as admin: ulx adduser Verzerrung superadmin
It says I do not have access to that command. So I rejoin like a few of the forum posts say to, and absolutely nothing changes. How is this even suppose to work? the tutorials never say ANYTHING about any sort of passwords, what is to stop someone from coming in and typing that command on my server and giving themselves access? How does the system know I am the owner trying to gain access to my own server? But apparently it does not.
I am probably missing something really obvious but I can not seam to figure out how to set some things up
Re: I cant make myself an admin to my server!
« Reply #1 on: January 19, 2012, 11:54:12 am »
You're supposed to run that command on the SERVER console, not the client console. If you have access to the server console, then you have permission to at least promote yourself to superadmin.
Offline Seaxneat
« Reply #2 on: January 19, 2012, 12:39:44 pm »
How do i get to the server console then? I thought hitting that "~" key brought up the right command window.
« Reply #3 on: January 19, 2012, 12:56:00 pm »
If you're running the server as a separate process on your computer, you use that process to access the server console. If you're using a professional hosting company, how you get to the console depends on the particular company you're using. For us to help further we'd need more details on how you're hosting the garry's mod server.
Offline Seaxneat
« Reply #4 on: January 19, 2012, 12:59:16 pm »
Using Xenon server hosting
« Reply #5 on: January 19, 2012, 02:10:10 pm »
Go to your control panel and look for something labeled console, then make yourself an admin from there.
« Reply #6 on: January 19, 2012, 03:10:46 pm »
And, just so we're clear, because you seem to be new to server hosting, when Megiddo says Control Panel, we don't mean your Windows Control Panel.
We mean the tool your Xenon hosting pages usually calls a Control panel.
« Reply #7 on: January 19, 2012, 03:26:24 pm »
I think it's called TCAdmin (The control panel).  You go to "Server Administrator" or something in that area with Xenon.  Type the command in there.
