Author Topic: DarkRP custom job  (Read 10659 times)
Offline Digital Spit
DarkRP custom job
« on: February 23, 2012, 11:25:05 am »
TEAM_Ex = AddExtraTeam("example", Color(0, 255, 0, 255), "models/player/mossman.mdl", [[Derp...]]
, {}, "derp", 1, 55, 0, false, false, false) function(ply) return ply:GetUserGroup() == "donator" or ply:IsAdmin() end)
I guess what I'm asking for is just approval over it, as in is this the correct way to put the hook to allow certain jobs to be donator only.
Re: DarkRP custom job
« Reply #1 on: February 23, 2012, 06:36:16 pm »
I think you have a ")" that should be a ",".
AddExtraTeam("example", Color(0, 255, 0, 255), "models/player/mossman.mdl", [[Derp...]], {}, "derp", 1, 55, 0, false, false, false, function(ply) return ply:GetUserGroup() == "donator" or ply:IsAdmin() end)
I don't know anything about DarkRP (Assuming this is what this is), so I may be wrong.
« Last Edit: February 23, 2012, 06:40:01 pm by Aaron113 »
« Reply #2 on: February 23, 2012, 09:51:01 pm »
TEAM_VIPJOB = AddExtraTeam("SWAT CHIEF", -- Name
Color(238, 99, 99, 255), -- Team color
"models/player/mossman.mdl", -- Player model
[[The SWAT are under your command.
Use force when needed. You can either setup a base for you and your team within the police department
 or occupy an empty building around the town.]],  -- Job description
{"lockpick", "unarrest_stick","med_kit"}, -- Weapons
"swatchief", -- Command to become the job
1, -- Maximum amount of said job
75, -- Salary
0, -- Admin status
0, -- Has to vote
true, -- Has a license
nil, -- Needs to be job X in order to get this job
function(ply) return ply:GetUserGroup() == "vip" end -- The extra check function. Enter nil or nothing to not have an extra check
That's what I ended up using, I found a sample on the DarkRP site, the last line with "GetUserGroup" was something that had to be changed to specify a ULX group but you were right
Offline bsharpie
« Reply #3 on: May 30, 2013, 09:02:12 pm »
ok so i have been searching everywhere for help on this and cant find it i even tried everything i even went on your website and did all of the things there and it still did not work but i am trying to add in a custom job that my donators can use and i have two donator ranks VIP and VIPGOLD and i want all the jobs for VIP to be able to be used as VIPGOLD and when i use this coding it does not work
jobfunction(ply) return ply:GetUserGroup() == "VIP" or "VIPGOLD" ply:IsAdmin()  end
jobfunction(ply) return ply:GetUserGroup() == "VIP" or ply:GetUserGroup() == "VIPGOLD"  ply:IsAdmin()  end
« Reply #4 on: May 31, 2013, 05:26:04 am »
I think you want this:
  1. function(ply) return ply:GetUserGroup() == "VIP" or ply:GetUserGroup() == "VIPGOLD" or ply:IsAdmin() end
  2.
Offline bender180
    • Benders Villa
« Reply #5 on: May 31, 2013, 07:04:34 am »
You have to edit the player.lua to make it VIP only I can't explain it very well but I asked the same question and got a good answer here /index.php/topic,6000.0.html#msg28117
Offline Chef Ramsey
« Reply #6 on: May 31, 2013, 08:14:45 am »
TEAM_HITMAN = AddExtraTeam("NAME", {
   color = Color(153,51,51,255),
   model = "models/player/leet.mdl",
   description = [[TEXT]],
   weapons = {"weapon"},
   command = "vip",
   max = 1,
   salary = 100,
   admin = 0,
   vote = false,
   hasLicense = false,
        customCheck = function(ply) return table.HasValue({"rank", "rank", "rank", "rank", "rank", "rank"}, ply:GetNWString("usergroup")) end,
        CustomCheckFailMsg = "When pressing on job it comes a text, type what text you want here!"
In rank change what rank you want, like "admin", "fag" and more!
Make sure to delete ranks you dont want, just delete " "and text
Ask me questons http://steamcommunity.com/id/Ficidy/
