Author Topic: Teleportating gun  (Read 6906 times)
Offline Digital Spit
Teleportating gun
« on: February 27, 2012, 11:25:56 am »
So I had this thought just randomly but, would it be possible to script a SWEP but have it include ULX/ULib? Just thinkin'
Re: Teleportating gun
« Reply #1 on: February 27, 2012, 02:08:11 pm »
Absolutely.
You'd just need to program the SWEP to do various functions.
Megiddo even tinkered with a 'targetting site' Radial Menu many years ago.
I see no reason it couldn't be tied into a SWEP with more advanced features/better GUI, etc.
BTW, that Radial menu is 3+ years old, though I've not tested, it's doubtful it still works.
Just using it as an example that could be tied to a SWEP with Right/left clicks and other features.
Offline kropp
« Reply #2 on: February 27, 2012, 06:09:02 pm »
I might be able to make this. Give me some time since I'm new to coding.
I got this so far,
Help fix this up if you can lol
if SERVER then
AddCSLuaFile("shared.lua")
if CLIENT then
SWEP.PrintName = "Teleport"
SWEP.Slot = 0
SWEP.SlotPos = 3
SWEP.DrawAmmo = false
SWEP.DrawCrosshair = false
SWEP.Base = "weapon_cs_base2"
SWEP.Author = "Kropp"
SWEP.Instructions = "Left Click to Teleport"
SWEP.Contact = "james-kropp@hotmail.com"
SWEP.Purpose = "Teleport"
SWEP.IconLetter = "w"
SWEP.ViewModelFOV = 62
SWEP.ViewModelFlip = false
SWEP.AnimPrefix = "stunstick"
SWEP.Spawnable = false
SWEP.AdminSpawnable = true
SWEP.NextStrike = 0
SWEP.ViewModel = Model("models/weapons/v_stunbaton.mdl")
SWEP.WorldModel = Model("models/weapons/w_stunbaton.mdl")
SWEP.Sound = Sound("weapons/stunstick/stunstick_swing1.wav")
SWEP.Primary.ClipSize = -1
SWEP.Primary.DefaultClip = 0
SWEP.Primary.Automatic = false
SWEP.Primary.Ammo = ""
SWEP.Secondary.ClipSize = -1
SWEP.Secondary.DefaultClip = 0
SWEP.Secondary.Automatic = false
SWEP.Secondary.Ammo = ""
function SWEP:Deploy()
function SWEP:Initialize()
self:SetWeaponHoldType("normal")
self.Hit = {
Sound("weapons/stunstick/stunstick_impact1.wav"),
Sound("weapons/stunstick/stunstick_impact2.wav")
self.FleshHit = {
Sound("weapons/stunstick/stunstick_fleshhit1.wav"),
Sound("weapons/stunstick/stunstick_fleshhit2.wav")
function SWEP:PrimaryAttack()
if CurTime() < self.NextStrike then return end
self:SetWeaponHoldType("melee")
timer.Simple(0.3, function(wep) if wep:IsValid() then wep:SetWeaponHoldType("normal") end end, self)
self.Owner:SetAnimation(PLAYER_ATTACK1)
self.Weapon:EmitSound(self.Sound)
self.Weapon:SendWeaponAnim(ACT_VM_HITCENTER)
self.NextStrike = CurTime() + .3
if CLIENT then return end
local trace = self.Owner:GetEyeTrace();
    local Gear = self.Owner:GetTable().CurGear or 1;
function("Teleport", "Teleports you to a targeted location.", true,
function ( Player, Trace )
local EndPos = Player:GetEyeTrace().HitPos;
local CloserToUs = (Player:GetPos() - EndPos):Angle():Forward();
Player:SetPos(EndPos + (CloserToUs * 20));
Player:PrintMessage(HUD_PRINTTALK, "Teleported.");
function SWEP:SecondaryAttack()
("Kill Player", "Aim at a player to slay him.", false,
if IsValid(Trace.Entity) and Trace.Entity:IsPlayer() then
Trace.Entity:Kill();
Player:PrintMessage(HUD_PRINTTALK, "Player killed.");
function SWEP:Reload()
timer.Destroy("rp_stunstick_threaten")
timer.Create("rp_stunstick_threaten", 1, 1, function() self:SetWeaponHoldType("normal") end)
if not SERVER then return end
if self.LastReload and self.LastReload > CurTime() - 0.1 then self.LastReload = CurTime() return end
self.Owner:EmitSound("weapons/stunstick/spark"..math.random(1,3)..".wav")
if CLIENT then
local function StunStickFlash()
local alpha = 255
hook.Add("HUDPaint", "Teleport Stick", function()
alpha = Lerp(0.05, alpha, 0)
surface.SetDrawColor(255,255,255,alpha)
surface.DrawRect(0,0,ScrW(), ScrH())
if math.Round(alpha) == 0 then
hook.Remove("HUDPaint", "Teleport Stick")
end)
usermessage.Hook("StunStickFlash", StunStickFlash)
« Last Edit: February 27, 2012, 06:28:37 pm by kropp »
« Reply #3 on: February 29, 2012, 11:34:19 am »
I got this so far,
if SERVER then
if CLIENT then
SWEP.Slot = 0
SWEP.SlotPos = 3
SWEP.NextStrike = 0
self.Hit = {
self.FleshHit = {
if CLIENT then
local alpha = 255
end)
I'm going to test this out and see if it works o.O
Offline kropp
« Reply #4 on: February 29, 2012, 04:17:47 pm »
This does not work. Its a rough draft need some one to fix it up.
« Reply #5 on: February 29, 2012, 05:04:00 pm »
How long have you been learning lua for?
Offline kropp
« Reply #6 on: February 29, 2012, 09:55:58 pm »
Just started thats why it does not work yet. Need some help
