Author Topic: Chat prefixes/tags/titles/names  (Read 26327 times)
Offline sme4gle
« on: March 21, 2012, 04:55:50 am »
Hello, ive been searching AGES for a plugin or code to make something like this for the chat:
[Admin] sme4gle: Hello you!
[Trusted] Shadow: Hi there Sme4gle :D
But none of em seem to be working how i want ... ive tried like 4-5 different codes half of em doesnt work or is for evolvemod
Re: Chat prefixes/tags/titles/names
« Reply #1 on: March 21, 2012, 01:58:57 pm »
Sme4gle, due to the current ways chat hooks can be so easily broken if not done right, Team Ulysses will never support it within ULX.
Megiddo says as much in this thread, which also has, aptly stated, unsupported, untested, code by another community (and silent partner) Team Ulysses member.
Searching from the forum front page found me this.
/index.php/topic,5391.0.html
That's not to say Garry may not somehow change things in the future which make it not so easy to break, but, currently, no, not now.
Offline sme4gle
« Reply #2 on: March 22, 2012, 01:42:54 am »
ive tried that one before, but i cant get it working :/
local function lOnPlayerChat( ply, strText, bTeamOnly, bPlayerIsDead, bPlayerIsOwner, bPlayerIsCoowner, bPlayerIsSuperadmin, bPlayerIsAdmin, bPlayerIsOperator, bPlayerIsRespected, bPlayerIsGuest )
    local tab = {}
    local lTeam = 0
    if( IsValid( ply ) ) then
        lTeam = ply:Team()
    table.insert( tab, Color( team.GetColor( lTeam ) ) )
    table.insert( tab, "[" .. team.GetName( lTeam ) .. "] " )
    if ( bPlayerIsOwner ) then
        table.insert( tab, Color( 255, 255, 255 ) )
        table.insert( tab, "[Owner] " )
    if ( bPlayerIsCoowner ) then
        table.insert( tab, "[Co-Owner] " )
    if ( bPlayerIsSuperadmin ) then
        table.insert( tab, "[Super-Admin] " )
    if ( bPlayerIsAdmin ) then
        table.insert( tab, "[Admin] " )
    if ( bPlayerIsOperator ) then
        table.insert( tab, "[Operator] " )
    if ( bPlayerIsRespected ) then
        table.insert( tab, "[Respected] " )
    if (bPlayerIsGuest ) then
        table.insert( tab, "[Guest] " )
    if ( IsValid( ply ) ) then
        table.insert( tab, ply:GetName() )
        table.insert( tab, "Console" )
    table.insert( tab, ": "..strText )
    chat.AddText( unpack(tab) )
    return true
hook.Add( "OnPlayerChat", "PlayerChatTeamPrefix", lOnPlayerChat )
I'm not that good in lua but i thought this was kind of correct isnt it?
« Reply #3 on: March 23, 2012, 07:05:48 pm »
Elaborate on "can't get it working". No change in behavior whatsoever? Are you sure you installed it correctly?
Offline Dimstar
« Reply #4 on: August 29, 2013, 05:55:15 am »
I found one that works for my server... here:
CreateClientConVar("chat_tags_color_r", 255, true, false)
CreateClientConVar("chat_tags_color_g", 255, true, false)
CreateClientConVar("chat_tags_color_b", 255, true, false)
CreateClientConVar("chat_tags_color_a", 255, true, false)
local Tags =
--Group    --Tag     --Color
{"user", "[User] ", Color(212, 67, 255, 255) },
{"admin", "[ADMIN] ", Color(0, 0, 255, 255) },
{"superadmin", "[SUPERADMIN] ", Color(255, 0, 0, 255) },
{"owner", "[OWNER] ", Color(0, 255, 0, 255) }
hook.Add("OnPlayerChat", "Tags", function(ply, strText, bTeamOnly)
if IsValid(ply) and ply:IsPlayer() then
for k,v in pairs(Tags) do
if ply:IsUserGroup(v[1]) then
local R = GetConVarNumber("chat_tags_color_r")
local G = GetConVarNumber("chat_tags_color_g")
local B = GetConVarNumber("chat_tags_color_b")
local A = GetConVarNumber("chat_tags_color_a")
local nickteam = team.GetColor(ply:Team())
if !bTeamOnly then
chat.AddText(v[3], v[2], nickteam, ply:Nick(), color_white, ": ", Color(R, G, B, A), strText)
return true
chat.AddText(v[3], v[2], nickteam, "(TEAM) ", ply:Nick(), color_white, ": ", Color(R, G, B, A), strText)
return true
if !IsValid(ply) and !ply:IsPlayer() then
local ConsoleColor = Color(0, 255, 0) --Change this to change Console name color
chat.AddText(ConsoleColor, "Console", color_white, ": ", strText)
return true
end )
« Reply #5 on: August 29, 2013, 01:51:07 pm »
Psst. Megiddo. Stop waking up posts from 2012.
:P
« Reply #6 on: August 29, 2013, 08:54:08 pm »
He didn't. :D As far as I can tell.
« Reply #7 on: August 30, 2013, 03:03:44 pm »
Oops.
Psst. Hey, Dimstar, no need to wake up posts from 2012.
(Though, admittedly, your post does answer a question...even if it was over a year ago asked)
« Reply #8 on: August 30, 2013, 03:09:22 pm »
The only thing I can think of is people find these posts using the search feature (Either through the website or through a search engine). Ergo: You should be quite thrilled Jam! :D
Offline Wully616
    • WullysGamers
« Reply #9 on: September 01, 2013, 04:33:26 am »
I have this script on my server, no idea where I got it, but it seems to work fine except some of the colours of the ranks come out white. I haven't really tried investigating it because it hasn't bothered me before.
prefix.lua in garrysmod/addons/ulx/lua/ulx/modules/cl
    function insertChatTags(ply, msg)
            if ply:IsValid() then
                    local ply_team = ply:Team()
                    local team_name = team.GetName( ply_team )
                    --local h,s,v = ColorToHSV( team.GetColor( ply_team ) )
                    --local comp_col = HSVToColor( 180-h, s, v )
                    --PHX-Server specifics
                    if ( team_name == "Leader Builder" ) then
                            comp_col = Color(55,126,206)
                    elseif ( team_name == "Admin Builder" ) then
                            comp_col = Color(79,115,158)
                    elseif ( team_name == "Wullys Builder" ) then
                            comp_col = Color(0,178,255)
                    elseif ( team_name == "Ultimate Builder" ) then
                            comp_col = Color(121,0,221)
                    elseif ( team_name == "Precision Builder" ) then
                            comp_col = Color(0,147,12)
                    elseif ( team_name == "Loyal Builder" ) then
                            comp_col = Color(173,0,23)
                    elseif ( team_name == "Creative Builder" ) then
                            comp_col = Color(0,13,132)
                    elseif ( team_name == "Novice Builder" ) then
                            comp_col = Color(255,242,0)
                    elseif ( team_name == "Bronze Builder" ) then
                            comp_col = Color(135,81,0)
                    elseif ( team_name == "Silver Builder" ) then
                            comp_col = Color(135,135,135)
                    elseif ( team_name == "Gold Builder" ) then
                            comp_col = Color(237,197,0)
                    elseif ( team_name == "Respected" ) then
                            comp_col = Color(169,186,198)
                    elseif ( team_name == "user" ) then
                            comp_col = Color(100,100,100)
                            team_name = "New Builder"
                            comp_col = Color(255, 255, 255)
                    chat.AddText( team.GetColor( ply_team ), "[",comp_col, team_name,team.GetColor( ply_team ), "] ", ply:GetName(), color_white, ": ", msg )
                    return true
    hook.Add( "OnPlayerChat", "ulx_chattags", insertChatTags )
[/url]
