How would I add a command, and make all commands silent?
Topic: How would I add a command, and make all commands silent? (Read 9278 times)
NnyAskC
March 24, 2012, 06:25:24 pm »
Okay so, first of all how would I go about adding a command ie a !modban that would ban someone for 1440 instead of whatever you type in.
Second is how would I go about making all admin commands appear only to other admins?
JamminR
Ulysses Team Member
Sertafide Ulysses Jenius
Re: How would I add a command, and make all commands silent?
March 24, 2012, 10:29:44 pm »
Re: Command
See
/index.php/topic,4464.0.html
Start and Read those, ask questions from there
See also
http://www.ulyssesmod.net/docs
for ULib documentation.
ULX has a little documentation, but it's mostly notes/comments within the lua files themselves.
Re: Command echos.
See your /addons/ulx/data/ulx/config.txt.
Copy it to your gmod/data/ulx/config.txt, edit from there. There are several echo states.
I believe one of them makes admin only echos.
NnyAskC
Reply #2 on:
March 25, 2012, 06:02:16 pm »
Thank you! ^_^
One thing though, the only echo modes are what I see below.
I only see
"Off": No echos at all.
"Anonymous": Except for admin+ shows "(Someone) did command"
"Full": You should be able to guess this one. =P
Last Edit: March 25, 2012, 07:39:51 pm by NnyAskC
Megiddo
Ulysses Team Member
Project Lead
Reply #3 on:
April 20, 2012, 12:47:28 pm »
If you're willing to modify lua files for the admin-echoes
only
, I'd be willing to help.
