[SM] You don't have access.
Topic: [SM] You don't have access. (Read 8527 times)
Digital Spit
Jr. Member
May 07, 2012, 01:13:18 pm »
Hello and the title says it all everytime myself or a server admin enters a command.
The command will go execute successfully however we get a message that says
Code:
[Select]
[SM] You do not have access to this command
Attached is a pictured
Any possible solutions? Only recently has this been starting to happen!
JamminR
Ulysses Team Member
Sertafide Ulysses Jenius
Re: [SM] You don't have access.
May 07, 2012, 02:13:16 pm »
Some mod, or code you've edited, is conflicting with ULX. Especially if it's occuring in chat commands.
Some idiot mod is probably grabbing on chat hook and returning true.
Megiddo
Ulysses Team Member
Project Lead
Reply #2 on:
May 07, 2012, 02:37:13 pm »
Some mod that goes by the abbreviation 'SM', probably. ULX returns "You do not have access to this command, <insert name here>." if you don't have access.
Digital Spit
Jr. Member
Reply #3 on:
May 07, 2012, 03:08:13 pm »
Hmmm I'll have to retrace my steps and figure this out!
Cpt. David
Reply #4 on:
May 08, 2012, 06:37:46 pm »
It's SourceMod. You probably added that, and they are both conflicting.
Derp.
Digital Spit
Jr. Member
Reply #5 on:
May 11, 2012, 10:56:29 pm »
Yes, source mod is installed. I don't really use it so I'll delete it. Thank you David!
Cpt. David
Reply #6 on:
May 12, 2012, 10:08:43 pm »
No problem.
Derp.
