Author Topic: [Fun] Bodyslide  (Read 5897 times)
Offline pikkip
[Fun] Bodyslide
« on: May 22, 2012, 12:32:06 pm »
I got a random and wired idea! lets add !bodyslide
like if I do "!bodyslide Bot01" I am making an animation where i can see in 3rd person shooter my standing on him while hes laying down and where i can control where i slide... like a skateboard?
I just had this random idea. Its mostly for fun and entertaintment
P.S.: If you do it on yourself, you will slide your own model but without a actual person under, just a body/ragdoll
        And if you just use !bodylide it will do the same as if it was yourself
(If you do it on a person like "!bodyslide Bot01" the actual person will layer under you, and you will stand on him, where your both sees in 3rd perspective/ 3rd person shooter)
Re: [Fun] Bodyslide
« Reply #1 on: May 26, 2012, 12:50:47 pm »
I think it would be easier if you made the command "!skateon". But that's just preference.
Re: [Fun] Bodyslide
« Reply #2 on: May 26, 2012, 02:56:24 pm »
Interesting idea.
Hellfox, you made the beta zombify, perhaps you could use some of the same control ideas with it.
Would be a good way to learn player animation controls.
If possible freeze the body position of a ragdoll while still allowing it to move in 3d space (to prevent lag..moving ragdolls body parts can really muck up a server, at least they could last time I played consistently a year or two ago)
Then figure out the crouch/jump positions of someone riding the ragdoll.
