Author Topic: Function Add Things By Time ( Megiddo HELP Please Or Who Know )  (Read 4504 times)
Offline Schiaffino
Hi well i have this code ( that people gain exp when they kill an user or an npc or per hit )
BUT I WANT TO KNOW HOW CAN I ADD A LINE TO PEOPLE EARN ( EXP ) BY ONLINE TIME, Who can help me with that ? thanks.
  1. /*********************************** TODO: Text data? More Powerups? Other player's EXP on screen? More damage?  *******************************************/
  2.
  3.
  4. local EXP_INC = 1                       // The experience gained on every shot
  5. local EXP_USENPC = 2                    // 0 = Players as exp objects, 1 = NPCs as exp objects, 2 = both
  6. local EXP_DEATHLOSS = 0.03              // The percentage of exp you lose on death (3 percent in this case)
  7. local EXP_STOPATMAX = 1         // Whether or not player's stop gaining exp at the maximum level (1 for they do)
  8. local EXP_USETXT = 1            // Whether or not to use SQL or .txt files to store the data (1 using .txt)
  9.
  10.
  11. // Let's make the files so we can store the exp
  12. sql.Query("CREATE TABLE IF NOT EXISTS exp_pdata('steam' TEXT NOT NULL, 'exp' INTEGER NOT NULL, 'curlevel' INTEGER NOT NULL, 'nextlevel' INTEGER NOT NULL, 'levelnum' INTEGER NOT NULL, PRIMARY KEY('steam'));")
  13. if not file.Exists("exp_store.txt") and EXP_USETXT == 1 then file.Write("exp_store.txt","") end
  14.
  15.
  16.
  17. // Just a quick function to print things into everyone's chat
  18. local function PrintAll(msg) for _,v in ipairs(player.GetAll()) do v:ChatPrint(msg) end end
  19.
  20.
  21.
  22.
  23. // Some writing/reading functions if you're using text files: still a work in progress
  24. local function WriteData(ply)
  25.         local lines = string.Explode("\n",file.Read("exp_store.txt"))
  26.         local towrite = ""
  27.         for k,v in ipairs(lines) do
  28.                 local values = string.Explode(" ",v)
  29.                 if values[1] != ply:SteamID() then towrite = towrite..v
  30.                 else end
  31.         end
  32.         file.Write("exp_store.txt",
  33.         file.Read("exp_store.txt")..ply:SteamID().." "..ply:GetNWInt("Exp").." "..ply:GetNWInt("CurLevel").." "..ply:GetNWInt("NextLevel").." "..ply:GetNWInt("LevelNum").."\n")
  34. end
  35.
  36. local function LoadData(ply)
  37.         local lines = string.Explode("\n",file.Read("exp_store.txt"))
  38.         for _,v in ipairs(lines) do
  39.                 local values = string.Explode(" ",v)
  40.                 if values[1] == ply:SteamID() then
  41.                         ply:SetNWInt("Exp",values[2])
  42.                         ply:SetNWInt("CurLevel",values[3])
  43.                         ply:SetNWInt("NextLevel",values[4])
  44.                         ply:SetNWInt("LevelNum",values[5])
  45.                 end
  46.         end
  47. end
  48.
  49.
  50. // The markers at which you gain a level (always leave the 0, don't go negative or put something before 0)
  51. levelups = {
  52. 0,
  53. 50,
  54. 100,
  55. 250,
  56. 500,
  57. 1000,
  58. 2500,
  59. 5000,
  60. 10000,
  61. 20000,
  62. 30000,
  63. 40000,
  64. 50000,
  65. 60000,
  66. 70000,
  67. 80000,
  68. 90000,
  69. 100000,
  70. 110000}
  71.
  72. /*********************************************************** GAMEMODE HOOKS ****************************************************************/
  73.
  74. // Give experience/level up on hit an npc or player
  75. function AddEXP( ply, hitgroup, dmginfo )
  76.         local attacker = dmginfo:GetAttacker()
  77.         if attacker:IsPlayer() then
  78.                 if EXP_STOPATMAX == 1 and attacker:GetNWInt("CurLevel") == levelups[table.Count(levelups)] then return end
  79.                 attacker:SetNWInt("Exp",attacker:GetNWInt("Exp")+EXP_INC)
  80.
  81.                 if table.HasValue(levelups,attacker:GetNWInt("Exp")) then
  82.                         local leveln = 1
  83.                         for k,v in ipairs(levelups) do if v == attacker:GetNWInt("Exp") then leveln = k end end
  84.                         if leveln == table.Count(levelups) then PrintAll(attacker:Name().." has reached the maximum level!")
  85.                         else PrintAll(attacker:GetName().." has now reached level "..leveln.."!") end
  86.                         attacker:SetNWInt("NextLevel",levelups[leveln+1])
  87.                         attacker:SetNWInt("CurLevel",levelups[leveln])
  88.                         attacker:SetNWInt("LevelNum",leveln)
  89.                         attacker:SendLua("surface.PlaySound(\"achievements/achievement_earned.mp3\")")
  90.                 end
  91.
  92.         end
  93. end
  94.
  95.
  96.
  97. // Check if we want to use NPCs or Players as the object of exp
  98. if EXP_USENPC == 1 then hook.Add("ScaleNPCDamage","NPCExp",AddEXP)
  99. elseif EXP_USENPC == 2 then
  100.         hook.Add("ScaleNPCDamage","NPCExp",AddEXP)
  101.         hook.Add("ScalePlayerDamage","PlayerExp",AddEXP)
  102. else hook.Add("ScalePlayerDamage","PlayerExp",AddEXP) end
  103.
  104.
  105.
  106. // Take away experience on death
  107. hook.Add("PlayerDeath","DownEXP",function(ply,wep,killer)
  108.         local exp = ply:GetNWInt("Exp")
  109.         local loss = math.Round(exp-exp*EXP_DEATHLOSS)
  110.         if loss < 0 then ply:SetNWInt("Exp",0)
  111.         elseif loss < ply:GetNWInt("CurLevel") then ply:SetNWInt("Exp",ply:GetNWInt("CurLevel"))
  112.         else ply:SetNWInt("Exp",loss) end
  113. end)
  114.
  115.
  116.
  117. // Save the values in the SQL on disconnect
  118. hook.Add("PlayerDisconnected","UpdateEXP",function(ply)
  119.         local exp = ply:GetNWInt("Exp")
  120.         local cur = ply:GetNWInt("CurLevel")
  121.         local new = ply:GetNWInt("NextLevel")
  122.         local lvl = ply:GetNWInt("LevelNum")
  123.         if EXP_USETXT == 1 then WriteData(ply)
  124.         else
  125.                 sql.Begin()
  126.                 sql.Query("UPDATE exp_pdata SET exp = "..exp.." WHERE steam = "..sql.SQLStr(ply:SteamID())..";")
  127.                 sql.Query("UPDATE exp_pdata SET curlevel = "..cur.." WHERE STEAM = "..sql.SQLStr(ply:SteamID())..";")
  128.                 sql.Query("UPDATE exp_pdata SET nextlevel = "..new.." WHERE STEAM = "..sql.SQLStr(ply:SteamID())..";")
  129.                 sql.Query("UPDATE exp_pdata SET levelnum = "..lvl.." WHERE STEAM = "..sql.SQLStr(ply:SteamID())..";")
  130.                 sql.Commit()
  131.         end
  132. end)
  133.
  134.
  135.
  136. // Load or create the player's values on initial connection
  137. hook.Add("PlayerInitialSpawn","RegisterEXP",function(ply)
  138.         if not tonumber(sql.QueryValue("SELECT exp FROM exp_pdata WHERE steam =  "..sql.SQLStr(ply:SteamID())..";")) then
  139.                 sql.Query("INSERT INTO exp_pdata VALUES("..sql.SQLStr(ply:SteamID())..",".. 0 ..",".. 0 ..","..levelups[2]..",".. 1 ..");")
  140.                 ply:SetNWInt("Exp",0)
  141.                 ply:SetNWInt("CurLevel",0)
  142.                 ply:SetNWInt("NextLevel",levelups[2])
  143.                 ply:SetNWInt("LevelNum",1)
  144.         else
  145.         sql.Begin()
  146.         ply:SetNWInt("Exp",tonumber(sql.QueryValue("SELECT exp FROM exp_pdata WHERE steam =  "..sql.SQLStr(ply:SteamID())..";")))
  147.         ply:SetNWInt("CurLevel",tonumber(sql.QueryValue("SELECT curlevel FROM exp_pdata WHERE steam =  "..sql.SQLStr(ply:SteamID())..";")))
  148.         ply:SetNWInt("NextLevel",tonumber(sql.QueryValue("SELECT nextlevel FROM exp_pdata WHERE steam =  "..sql.SQLStr(ply:SteamID())..";")))
  149.         ply:SetNWInt("LevelNum",tonumber(sql.QueryValue("SELECT levelnum FROM exp_pdata WHERE steam =  "..sql.SQLStr(ply:SteamID())..";")))
  150.         sql.Commit()
  151.         end
  152. end)
  153.
  154.
  155.
  156. /********************************************************** CONCOMMANDS **********************************************************************/
  157.
  158. local chatcommands = {}
  159.
  160. // Allow admins to change the exp level of players
  161. concommand.Add("exp_setlevel",function(ply,cmd,args)
  162.         if ply:IsAdmin() then
  163.                 leveln = tonumber(args[2])
  164.                 local tar
  165.                 for _,v in ipairs(player.GetAll()) do if string.match(v:Name(),args[1]) then tar = v end end
  166.
  167.                 if not tar then ply:ChatPrint("Please use a valid target! (format <player name> <level>") return end
  168.                 if leveln < 1 or leveln > (table.Count(levelups)+1) then ply:ChatPrint("Please select a valid level between 1 - ".. table.Count(levelups) .. ".") return end
  169.
  170.                 tar:SetNWInt("Exp",levelups[leveln])
  171.                 tar:SetNWInt("CurLevel",levelups[leveln])
  172.                 if leveln == table.Count(levelups) then tar:SetNWInt("NextLevel",levelups[leveln])
  173.                 else tar:SetNWInt("NextLevel",levelups[leveln+1]) end
  174.                 ply:SetNWInt("LevelNum",leveln)
  175.
  176.                 ply:ChatPrint("You set "..tar:Name().."'s level to "..leveln..".")
  177.         end
  178. end)
  179. table.insert(chatcommands,{"setlevel","exp_setlevel"})
  180.
  181.
  182. // Allow admins to change the exp increment per hit via console
  183. concommand.Add("exp_setinc",function(ply,cmd,args)
  184.         if ply:IsAdmin() then
  185.                 local inc = tonumber(args[1])
  186.                 if inc < 1 then ply:ChatPrint("Please use a positive integer above zero.") return end
  187.                 EXP_INC = tonumber(args[1])
  188.         end
  189. end)
  190. table.insert(chatcommands,{"setinc","exp_setinc"})
  191.
  192.
  193.
  194. // Allow anyone to check their current level
  195. concommand.Add("exp_curlevel",function(ply,cmd,args)
  196.         for k,v in ipairs(levelups) do if ply:GetNWInt("CurLevel") == v then ply:ChatPrint("You are on level "..k..".") end end
  197. end)
  198. table.insert(chatcommands,{"curlevel","exp_curlevel"})
  199.
  200.
  201. // Allow admins to save everyone's data in the SQL
  202. concommand.Add("exp_savedata",function(ply,cmd,args)
  203.         if ply:IsAdmin() then
  204.                 sql.Begin()
  205.                 for _,v in pairs(player.GetAll()) do
  206.                         local exp = v:GetNWInt("Exp")
  207.                         local cur = v:GetNWInt("CurLevel")
  208.                         local new = v:GetNWInt("NextLevel")
  209.                         local lvl = v:GetNWInt("LevelNum")
  210.                         if EXP_USETXT == 1 then WriteData(v)
  211.                         else
  212.                                 sql.Query("UPDATE exp_pdata SET exp = "..exp.." WHERE steam = "..sql.SQLStr(ply:SteamID())..";")
  213.                                 sql.Query("UPDATE exp_pdata SET curlevel = "..cur.." WHERE STEAM = "..sql.SQLStr(ply:SteamID())..";")
  214.                                 sql.Query("UPDATE exp_pdata SET nextlevel = "..new.." WHERE STEAM = "..sql.SQLStr(ply:SteamID())..";")
  215.                                 sql.Query("UPDATE exp_pdata SET levelnum = "..lvl.." WHERE STEAM = "..sql.SQLStr(ply:SteamID())..";")
  216.                         end
  217.                 end
  218.                 sql.Commit()
  219.                 ply:ChatPrint("Data saved!")
  220.         end
  221. end)
  222. table.insert(chatcommands,{"savedata","exp_savedata"})
  223.
  224.
  225. // Just in case the SQL fails, let's check why
  226. concommand.Add("exp_debug",function(ply,cmd,args) if sql.LastError() then ply:ChatPrint(sql.LastError()) else ply:ChatPrint("No SQL errors!") end end)
  227. table.insert(chatcommands,{"debug","exp_debug"})
  228.
  229.
  230. // Get the data from the last save
  231. concommand.Add("exp_printsql",function(ply,cmd,args)
  232.         ply:ChatPrint("Data from previous save...")
  233.         ply:ChatPrint("Experience: "..tonumber(sql.QueryValue("SELECT exp FROM exp_pdata WHERE steam =  "..sql.SQLStr(ply:SteamID())..";")))
  234.         ply:ChatPrint("Base Level Experience: "..tonumber(sql.QueryValue("SELECT curlevel FROM exp_pdata WHERE steam =  "..sql.SQLStr(ply:SteamID())..";")))
  235.         ply:ChatPrint("Next Level: "..tonumber(sql.QueryValue("SELECT nextlevel FROM exp_pdata WHERE steam =  "..sql.SQLStr(ply:SteamID())..";")))
  236.         ply:ChatPrint("Level Number: "..tonumber(sql.QueryValue("SELECT levelnum FROM exp_pdata WHERE steam =  "..sql.SQLStr(ply:SteamID())..";")))
  237. end)
  238. table.insert(chatcommands,{"printsql","exp_printsql"})
  239.
  240.
  241. // Get the data from right now
  242. concommand.Add("exp_printnw",function(ply,cmd,args)
  243.         ply:ChatPrint("Data at this moment...")
  244.         ply:ChatPrint("Experience: "..ply:GetNWInt("Exp"))
  245.         ply:ChatPrint("Base Level Experience: "..ply:GetNWInt("CurLevel"))
  246.         ply:ChatPrint("Next Level: "..ply:GetNWInt("NextLevel"))
  247.         ply:ChatPrint("Level Number: "..ply:GetNWInt("LevelNum"))
  248. end)
  249. table.insert(chatcommands,{"printnw","exp_printnw"})
  250.
  251.
  252. /******************************************************** CHAT COMMANDS **********************************************************************/
  253.
  254.
  255. // So the chatcommands will work
  256. hook.Add("PlayerSay","EXP_Chat",function(ply,str,toall)
  257.         if string.Left(str,2) != "**" then return str end
  258.         local cmd = string.Explode(" ",string.sub(str,3,string.len(str)))
  259.         local cmdstr = ""
  260.         for k,v in ipairs(cmd) do if k != 1 then cmdstr = cmdstr .. " ".. v end end
  261.         for _,v in ipairs(chatcommands) do
  262.                 if cmd[1] == v[1] then ply:ConCommand(v[2].." "..cmdstr) end
  263.         end
  264.         return ""
  265. end)
  266.
Thanks !
Edit by Megiddo: Added code tags
« Last Edit: May 27, 2012, 03:22:05 pm by Megiddo »
Re: Function Add Things By Time ( Megiddo HELP Please Or Who Know )
« Reply #1 on: May 27, 2012, 03:23:03 pm »
Please post code related things in the developer section and put code in code tags.
You can use the online time API provided by UTime for this purpose...
