Author Topic: Auto Promote PROBLEM  (Read 5879 times)
Offline Schiaffino
« on: May 28, 2012, 06:09:20 pm »
Hi well , i download the Auto-Promote System and i put it on my dedicated server ( Addons/AutoPromoted/lua/etc.... )
I Put it on Addons Folder...
BUT WHEN I START THE SERVER ( THIS " MOD " ) DO NOT START. IDK ITS LIKE THE SERVER DO NOT LOAD THE MOD
Im Using DarkRP 2.4.2 What's can be the problem ?
« Last Edit: May 28, 2012, 07:12:59 pm by Schiaffino »
Re: Auto Promote PROBLEM
« Reply #1 on: May 28, 2012, 07:48:46 pm »
Are you getting any error messages in the console on start-up? The Auto-Promote system is not officially supported and neither is DarkRP. Likely if the addon is installed correctly then DarkRP is most likely causing the problem.
Game Modes in generally don't like some addons because of how they override hooks (if they are poorly coded) and DarkRP is notorious for not playing well with other plugins, especially ULib/ULX.
Offline Schiaffino
« Reply #2 on: May 28, 2012, 07:52:55 pm »
D: i have a friend that its running a darkrp server WITH: UTime and Promote System and Credit system etc.. full system and without problems
:s maybe he make something especial to make those things work ?
« Reply #3 on: May 29, 2012, 02:48:59 pm »
It is possible. Why don't you ask your friend what he is using. It is hard for me to say what your problem is without more information. I need for you to post any lua console errors you are getting when you server starts up.
Are you running your server on a dedicated platform or at home or is it a listen server?
Offline Schiaffino
« Reply #4 on: May 29, 2012, 04:15:27 pm »
on a NFO Garrys Mod Server Listening Server not Dedicated Server.
Offline Schiaffino
« Reply #5 on: May 29, 2012, 07:01:12 pm »
Problem Solved ! =)
