Access
Topic: Access (Read 5177 times)
xrawR
Guest
Access
December 02, 2006, 03:09:24 pm »
I can't get admin on my server... I put it in the lua/Ulib/users.ini just like it says to.. I read EVERYTHING and I run a ded. server I even tried the access generator... anytips?
spbogie
Ulysses Team Member
Sr. Member
Re: Access
December 02, 2006, 05:40:32 pm »
In order to assist you we need some information.
Please post:
1) The contense of your users.ini file.
2) The output of "lua tprint(ULib.mainUCL)" in console.
3) The output of "status" in console.
The Pro
Re: Access
Reply #2 on:
December 03, 2006, 02:26:27 pm »
If you are using Gmod10 all the userdata gos inside the garrysmod\data\users.txt file.
Access
