Author Topic: Low FPS on Garry's mod RP. ( Linux server. )  (Read 7377 times)
« on: July 18, 2012, 08:25:58 pm »
On my server people run at lower FPS rates then usual, as in some one who runs at 60 - 120 FPS would run at 5 - 15 FPS on the server.
I have found 1 thread that may relate to my problem how ever it is not likely because the server has been bought from NFO Servers.
Here it is... http://forums.steampowered.com/forums/showthread.php?t=1418556
And here are some basic server specs...
CPU: 0.00
In (KB/s): 46.09
Out (KB/s): 80.17
Uptime: 90
Map changes: 0
FPS: 11.80
Players: 25/45
Connects: 177
ULX version: 3.54
ULib version: 2.42
Gamemode: ZombieRP 2.4.2
Map: zombiesurvival_mojave_lonesome
Dedicated server: true
Active addons on this server:
zps by , version 1 (March 16th 2011)
zeno_clash by ACE Team, version 1 (May 8th 2009)
ups_menu by RynO-SauruS & Hellfox_15, version 1 (25th April 2011)
ulx by Team Ulysses, version 3.54 (04/27/12)
tf2 by Valve, version 1 (29th October 2007)
smartsnap by Syranide, version 0.9.5 ()
portal by Valve, version 1 (29th October 2007)
no_collide_multi by Narkaleptic, version 1.1 (December 19th 2006)
left4dead2 by , version 1 (April 5th 2011)
left4dead by , version 1 (March 16th 2011)
keypad cracker by Chief Tiger, version 1 (28th June 2009)
keypad by Robbis_1 (aka Killer HAHA), version 1.4 (25th February 2008)
hl2_ep2 by Valve, version 1 (29th October 2007)
fading_doors by Lexi, version 1.1 (08/08/2010)
dystopia by , version 1 (March 16th 2011)
drugs_mod_v3 by cheesylard, version 2 (24 January 2009)
diprip by , version 1 (March 16th 2011)
day-of-defeat by Valve, version 1 (22nd August 2006)
counter-strike by Valve, version 1 (5th August 2006)
aoc by , version 1 (April 7th 2011)
WireExtras by Anticept and respective developers, version SVN (3rd June 2008)
Wire by Wire Team, version Github ((null))
Wenlis Tools by Wenli, version 1.44 (12th August 2010)
WeightSTool by Spoco, version 1.21 ((null))
URS by xAaron113x, version Beta (N/A)
ULib by Team Ulysses, version 2.42 (01/01/12)
ULX_SVN-HeLLFox_15 by RynO-SauruS & Hellfox_15, version 1 (25th April 2011)
ULX-Jukebox by RynO-SauruS, version 1.4 (28th March, 2012)
Stacker STool by -, version 2.2 (19th January 2007)
Smart_Constraint by Spacetech, version 1.2.2 ()
RiotShield by Donkie, Model by Arleitiss, version 1.1 (52)
Renamon 2009 by GuyNumbers, version 2 (October 10, 2009)
Realistic Fall Damage by ChicknWafflZ, version 1 (October 19th, 2009)
Pet Class by HeLLFox_15, version 0.1 (Alpha)
MoneyModels by , version (13 03 08)
MoneyDetectorFIXED by philxyz fixed by chapman, version 2 (29th June 2010)
Molotov Cocktail by Zinze[RPB]/Falco, version 1 ()
HeLLFox_15-SWEPS by HeLLFox_15, version 0.1 (Alpha)
Gingerbread man by ConeX, version 1 (17.May 2011)
E2 - DarkRP Money by Daranable, version 0.1 ((null))
DarkRP_Scoreboard by DarkRP, version 0.1 ()
Dark Female Assassin PM by Model ShoTGuNGuY49 and fixed by NiKouT, version 2 (4/1/11)
CSS Realistic Weapons 4.0 NoSmoke by WORSHIPPER, version 4 (13th February 2008)
AntiMinge by TheLastPenguin and HeLLFox - remove this and you have no heart., version 0.0.1 (IDK)
Adv Duplicator 2 by Advanced Duplicator 2 Team: TB, emspike, version SVN (SVN)
Adv Duplicator by TAD2020, version 1.85 (June 28th 2009)
I can confirm that when the LUA cache glitches ( LUA cache could not be downloaded. ) the server runs much smoother.
About our own custom code, I don't really want to hand it out so if you are willing to help and you are good with LUA, I can PM you some code. I just need to be sure that I can trust you not to give it out.
Re: Low FPS on Garry's mod RP. ( Linux server. )
« Reply #1 on: July 19, 2012, 04:08:53 am »
If you want I can take a look a snips you think might be giving you problems. No promises though, it could be a number of things.
My suggestion would be to remove addons and add them back in one at a time until you get one that causes more than normal fps drops.
*Also* I moved the thread here to Off-Topic as this doesn't really have anything to do with any of the Ulysses projects.
