Author Topic: How would you add extra 'Global' targets  (Read 7959 times)
Offline iSnipeu
« on: July 28, 2012, 11:34:05 pm »
When your using ulx commands you can use things like ^ (to target yourself), * (to target everyone) and I'm pretty sure you can use % to target groups (e.g %admin)
Is there a way to add extra stuff to this?
For example "!slap &" (which could only target alive players).
« Last Edit: July 28, 2012, 11:51:10 pm by iSnipeu »
Re: How would you add extra 'Global' targets
« Reply #1 on: July 29, 2012, 05:34:37 am »
You certainly can. Just edit the ULib.getUsers and ULib.getUser functions in ulib/lua/ulib/shared/player.lua. The first function is used in cases where multiple targets are expected (eg, slap). The second function is used where only one target is expected (eg, ban). You'll only need to to add the relevant "elseif" case in each of these functions... you shouldn't need to edit any other pieces.
Be sure to let us know what additions you make, we'd love to hear about them.
Offline iSnipeu
« Reply #2 on: July 30, 2012, 12:57:35 am »
Thanks!
I've currently added # - this will only target alive players, you can use !# to target dead players
Here is the code if anyone wants it.
Remember this is in ulib/lua/ulib/shared/player.lua in the ULib.getUsers function @ line 109
if piece == "*" then -- All!
table.Add( tmpTargets, players )
elseif piece == "^" then -- Self!
if ply then
table.insert( tmpTargets, ply )
elseif piece == "#" then -- Alive players!
for _, pl in ipairs( players ) do
if pl:Team() != 1002 and pl:Alive() then
table.insert( tmpTargets, pl )
elseif piece == "@" then
if ply and ply:IsValid() then
local player = ULib.getPicker( ply )
if player then
table.insert( tmpTargets, player )
« Last Edit: July 31, 2012, 12:04:32 am by iSnipeu »
« Reply #3 on: July 30, 2012, 03:59:22 pm »
iSnipeu, you don't need to explicitly handle the "not" cases, that is "!#" and "!^". This is already being handled in the functions automagically. You only need to code the positive logic. :)
« Reply #4 on: July 30, 2012, 08:49:32 pm »
Meg, would our functions specifically target non-alive players though?
Offline iSnipeu
« Reply #5 on: July 31, 2012, 12:05:39 am »
Fixed it, I completely forgot about that.
« Reply #6 on: July 31, 2012, 04:58:42 am »
It's a general case to inverse the selection. The set operation is just (all players) - (positive selection) within the bounds of who you're allowed to target.
