Author Topic: ULX Errors With DarkRP  (Read 6771 times)
Offline Flamehead
« on: July 30, 2012, 04:30:06 pm »
Hello everyone, I've been trying to set up my server, ULX never worked properly for me (Because of a scripthook error when I made myself superadmin saying I was not "Authed"
 even after entering the correct RCON and doing an RCON echo...) but now when I run DarkRP I get a ton of ULX errors and it's generally unresponsive. And I downloaded from the official site, and considering it was working (Aside from the aforementioned superadmin problem) I'm not sure what the problem is..
Here is the complete console log from the start of Gmod (Which I just wiped clean, it has zero installed addons)
Mounting hl2.. OK
Mounting cstrike.. OK
Mounting dod.. SteamMountDepot: Error SteamMountFilesystem 300 - (dependency 4 (301))
SteamMountFilesystem(13236,301,0x1d52fd28=,0x1d52fc18) failed with error 116: Cache needs repair
OK
Mounting ep2.. OK
Mounting tf.. SteamMountDepot: Error SteamMountFilesystem 440 - (dependency 4 (441))
SteamMountFilesystem(13236,441,0x1d52fd28=,0x1d52fc18) failed with error 116: Cache needs repair
SteamMountDepot: Error SteamMountFilesystem 440 - (dependency 5 (442))
SteamMountFilesystem(13236,442,0x1d52fd28=,0x1d52fc18) failed with error 116: Cache needs repair
OK
Mounting episodic.. OK
Mounting hl2mp.. SteamMountDepot: Error SteamMountFilesystem 320 - (dependency 4 (321))
SteamMountFilesystem(13236,321,0x1d52fd28=,0x1d52fc18) failed with error 116: Cache needs repair
OK
Mounting portal.. OK
Mounting lostcoast.. OK
Mounting hl1.. No permission
Mounting hl1mp.. No permission
Mounting zeno_clash.. No permission
Mounting left4dead2.. Disabled
Mounting left4dead.. Disabled
Mounting diprip.. Disabled
Mounting zps.. Disabled
Mounting pvkii.. Disabled
Mounting dystopia.. Disabled
Mounting ageofchivalry.. Disabled
Garry's Mod server.dll Build #139 [Jul 26 2012 15:09:55]
maxplayers set to 128
Unknown command "sv_allow_wait_command"
Steam config directory: c:\program files (x86)\steam\steamapps\309978898\garrysmod\platform\config
CClientSteamContext logged on = 1
Both ConVars must be marked FCVAR_REPLICATED for linkage to work (v_ipitch_level)
Both ConVars must be marked FCVAR_REPLICATED for linkage to work (v_iroll_level)
Both ConVars must be marked FCVAR_REPLICATED for linkage to work (v_iyaw_level)
Both ConVars must be marked FCVAR_REPLICATED for linkage to work (v_ipitch_cycle)
Both ConVars must be marked FCVAR_REPLICATED for linkage to work (v_iroll_cycle)
Both ConVars must be marked FCVAR_REPLICATED for linkage to work (v_iyaw_cycle)
Both ConVars must be marked FCVAR_REPLICATED for linkage to work (cl_bobup)
Both ConVars must be marked FCVAR_REPLICATED for linkage to work (cl_bob)
Both ConVars must be marked FCVAR_REPLICATED for linkage to work (cl_bobcycle)
Both ConVars must be marked FCVAR_REPLICATED for linkage to work (cl_backspeed)
Both ConVars must be marked FCVAR_REPLICATED for linkage to work (cl_forwardspeed)
Both ConVars must be marked FCVAR_REPLICATED for linkage to work (cl_upspeed)
Both ConVars must be marked FCVAR_REPLICATED for linkage to work (cl_sidespeed)
Hud element 'CHudVote' doesn't have an entry 'CHudVote' in scripts/HudLayout.res
Garry's Mod client.dll Build #139 [Jul 26 2012 15:10:14]
maxplayers set to 1
Unknown command "cl_thirdperson"
Unknown command "hud_showemptyweaponslots"
Unknown command "sv_backspeed"
Not playing a local game.
GetAllManifestFiles:  Unable to load maplist.txt
Got toybox authentication
Network: IP 192.168.0.14, mode MP, dedicated No, ports 27015 SV / 27005 CL
Connecting to 23.29.126.142:27016...
Connected to 23.29.126.142:27016
FusionRP
Map: rp_downtown_fiend_night_v2
Players: 1 / 12
Build: 4993
Server Number: 1
ConVarRef ulx_welcomemessage doesn't point to an existing ConVar
SetConVar: No such cvar ( ulx_welcomemessage set to Welcome to %host%! We're playing %curmap%.), skipping
ConVarRef ulx_chattime doesn't point to an existing ConVar
SetConVar: No such cvar ( ulx_chattime set to 0), skipping
ConVarRef ulx_votemapsuccessratio doesn't point to an existing ConVar
SetConVar: No such cvar ( ulx_votemapsuccessratio set to 0.4), skipping
ConVarRef ulx_logecho doesn't point to an existing ConVar
SetConVar: No such cvar ( ulx_logecho set to 1), skipping
Browser Message: Uncaught ReferenceError: DownloadingFile is not defined - (null):0
Browser Message: Uncaught ReferenceError: SetFilesNeeded is not defined - (null):0
Browser Message: Uncaught ReferenceError: SetFilesTotal is not defined - (null):0
Browser Message: Uncaught ReferenceError: SetStatusChanged is not defined - (null):0
FusionRP
Players: 1 / 12
Build: 4993
Server Number: 1
No pure server whitelist. sv_pure = 0
SOLID_VPHYSICS static prop with no vphysics model! (models/props_lab/corkboard001.mdl)
Warning: using WorldTwoTextureBlend on a non-displacement surface.
Support for this will go away soon.
   - Material       : gm_construct/grass
   - Surface center : -1925 -1146 120
Warning: WorldTwoTextureBlend found on a non-displacement surface (material: gm_construct/grass). This wastes perf for no benefit.
Unable to initialize DirectSoundCapture. You won't be able to speak to other players.Decompressing data pack into virtual file system..
Lua cache file "cache/011e9979debf13c7ed9eec2debe1c59d.dua" does not exist. This indicates a server misconfiguration. Most likely fastdl is enabled, but the server host hasn't mirrored the pack.
Unable to load virtual file system!
Lua initialized (Lua 5.1)
Couldn't include file 'darkrp\gamemode\cl_init.lua' (File not found) (<nowhere>)
[cpp]
There was a problem opening the gamemode file 'darkrp/gamemode/cl_init.lua'
Registering gamemode 'darkrp' derived from 'base'
Sending 8 'User Info' ConVars to server (cl_spewuserinfoconvars to see)
Scanning for downloaded fonts..
Reloading Particles..
Client "" spawned in server (99.244.177.109:27005)<STEAM_0:1:18573181>.
Welcome to Bone-Storm | Semi-SeriousRP | Custom Jobs/Shipements/Printers! We're playing rp_downtown_fiend_night_v2.
Warning: Unhandled usermessage 'FRecieveGlobalInt'
EDIT by Megiddo: Added code tags
« Last Edit: July 30, 2012, 06:12:03 pm by Megiddo »
Offline Flamehead
Re: ULX Errors With DarkRP
« Reply #1 on: July 30, 2012, 04:33:11 pm »
There are a lot more but this posting limit mixed with the automatic system thinking I'm double posting is making it incredibly hard to post.
Warning: Unhandled usermessage 'DarkRPEffects'
Warning: Unhandled usermessage 'ULStart'
Warning: Unhandled usermessage 'e2fs'
Warning: Unhandled usermessage 'wire_ports'
Warning: Unhandled usermessage 'e2fd'
Warning: Unhandled usermessage 'e2fe'
Warning: Unhandled usermessage 'LoadModules'
Warning: Unhandled usermessage 'ULPacket'
Warning: Unhandled usermessage 'ULEnd'
Redownloading all lightmaps
Warning: Unhandled usermessage 'EGP_ScrWH_Request'
Warning: Unhandled usermessage 'DarkRP_Chat'
Unknown command: Wire_Welcome_Menu
] rcon_password "*****"
] rcon echo
autokick is disabled for Klaus
] rcon ulx adduser "Klaus" superadmin 1
(Console) added Klaus to group superadmin
Warning: Unhandled usermessage 'tsayc'
Warning: Unhandled usermessage '_Notify'
You're playing on ******* | Semi-SeriousRP | Custom Jobs/Shipements/Printers, enjoy your stay!
« Last Edit: July 30, 2012, 06:12:32 pm by Megiddo »
Offline Assault_Trooper
    • Trooper's Gaming Servers
« Reply #2 on: July 30, 2012, 04:45:25 pm »
The cl_init.lua in your DarkRP gamemode has an error and fails to load.
« Reply #3 on: July 30, 2012, 05:02:02 pm »
It doesn't appear to be an error with his cl_init.lua so much as a fastDL issue...
Make sure you are updating your fastDL with your luacache every time you make any changes to your servers files.
« Reply #4 on: July 30, 2012, 05:22:46 pm »
Oh yeah, didn't think of that. Just watched this part
[cpp]
But I guess it being completely missing is an error itself.  ::)
