Author Topic: UtimeMOO - Utime for MySQL (Linux Compatible)  (Read 71895 times)
Offline BlueGhostHD
Re: UtimeMOO - Utime for MySQL (Linux Compatible)
« Reply #30 on: August 12, 2013, 07:01:40 pm »
I need help setting up mysqloo for linux, I've done it for pc, but I don't understand what to do for linux and which files to use.
« Reply #31 on: August 12, 2013, 07:26:14 pm »
See the bottom of this post, which provides different files/links and locations.
http://facepunch.com/showthread.php?t=1220537
(all i know to do to help, but figure thats a start)
Offline BlueGhostHD
« Reply #32 on: August 12, 2013, 07:42:56 pm »
I've tried all of that, followed tutorials, etc. but it still won't work! :(
Offline TweaK
    • Garry's Mod Engineers
« Reply #33 on: August 12, 2013, 11:43:37 pm »
"Doesn't work" tells us absolutely nothing. Are you getting an error in your console? Have you installed the dll in lua/bin and libmysql alongside the srcds executable? Are you sure your database connection info is correct?
Offline BlueGhostHD
« Reply #34 on: August 13, 2013, 12:13:17 am »
Don't worry, I decided to backup all my work, and change the OS to Windows, because I've always preferred it over Linux :P
Edit: Now with mysqloo working, this addon shows no connectivity to the database I used.
« Last Edit: August 13, 2013, 07:59:03 am by BlueGhostHD »
Offline esfservers
« Reply #35 on: August 20, 2013, 04:59:05 pm »
[ERROR] addons/utimemoo/lua/autorun/cl_utime.lua:137: attempt to index global 'utilx' (a nil value)
  1. unknown - addons/utimemoo/lua/autorun/cl_utime.lua:137
Offline TweaK
« Reply #36 on: August 21, 2013, 06:33:57 pm »
I think you got an ancient version or something... try the one I posted
Offline Neoon
« Reply #37 on: July 11, 2014, 03:59:46 pm »
Uses sqlite instead of mysql so it dosent works, please fix it.
Offline crotoss
« Reply #38 on: July 21, 2014, 07:35:21 pm »
I am having an issue where random players get their times reset. They're still in the database just their time resets at 0.
Offline Malkeur
« Reply #39 on: August 02, 2014, 08:22:40 am »
I'd be down to try this but I'm curious, can you convert the data from the sv.db that the original utime uses to the mysql version this uses? I'd much rather use mysql.
Offline Bite That Apple
  • Apple Innovations 2010®
    • Fun 4 Everyone Gaming
« Reply #40 on: August 02, 2014, 03:28:30 pm »
That's a lot of work to convert mysqli to mysql in this game. I suppose someone would have to make another addon.
Offline crotoss
« Reply #41 on: September 29, 2014, 07:06:33 pm »
Using the version provided by TweaK https://dl.dropboxusercontent.com/u/7934790/gmod/utimem.zip
I still seem to have issues with peoples time being occasionally reset. Anyone else encountering this problem?
Offline Luk | twitch.tv/doctorluk
« Reply #42 on: April 06, 2015, 11:40:06 am »
I'm replying to this topic as my issue is directly related to the modified script released by TweaK.
The aim of using MySQL for Utime is to use it on a website and get some quick info about some players and stuff.
The stock UTime addon does not save the Steam-ID, nor the current name of the player. This addon does that, which is a nice feature that I need.
However, an issue with the names is that they are not being saved in UTF-8, so german umlauts are being destroyed and all other characters that many people use are destroyed, too.
I've already changed the encoding in my MySQL table to utf8_unicode_ci, but the names are still being butchered and I suspect lua to be doing that.
Is there a way to get the script to input UTF-8 encoded characters?
As an example:
Jünger² Gaboris being saved as
Jünger² Gabor
This is an excerpt of the update-query:
query( "UPDATE utime SET totaltime = " .. math.floor( ply:GetUTimeTotalTime() ) .. ", steamid = '" ..
ply:SteamID() .. "', playername = '" .. db:escape( ply:Nick() ) .. "' WHERE player = " ..
ply:UniqueID() .. ";", function() end )
I did it!
The thing that was missing was "SET NAMES 'utf8';" as the first query before any other queries. Also the playername row must be encoded in utf8_unicode_ci to allow UTF-8 encoded entries.
Here is how to install it:
I already have a UTime MySQL table with entries
1. Open your table structure via phpmyadmin
2. Edit the row "playername"
3. Change the collation to "utf8_unicode_ci"
If you do not have phpmyadmin and can only use SQL queries, use this one:
USE <database>;
ALTER TABLE  `utime` CHANGE  `playername`  `playername` VARCHAR( 100 ) CHARACTER SET utf8 COLLATE utf8_unicode_ci NOT NULL ;
and replace "<database>" with the name of your database where utime is installed.
This is the first time I install UTime with MySQL
1. You do not have to change anything, the script automatically constructs the playernames table with UTF-8 encoding
You find the modified scripts in an attachment to this post which you can only see when being logged in.
« Last Edit: April 07, 2015, 05:14:54 am by Luk | twitch.tv/doctorluk »
Host of Spielwiese der Erwachsenen, a German TTT Server for adults only.
« Reply #43 on: May 03, 2015, 07:12:54 pm »
It's not really fixable. It's supposed to be a really RARE issue though, because of utime saving the database information at 67 seconds, it's possible that before the player's time/data is loaded, the server saved when their data is at 0, small chance though.
« Reply #44 on: May 03, 2015, 08:40:16 pm »
Looks like it's fixed in the version posted right above you.  All he did was add a simple loaded check on the player.
