Author Topic: You do not have permission to...  (Read 8379 times)
Offline jajolt
« on: August 19, 2012, 11:38:32 am »
So when there's a disruption, I cannot type the ulx commands.  Instead, I have to go through !menu  and it takes longer,
It says (In the chat box)  You are not allowed to access this command.  I am superadmin.
People also get things like You are not allowed to spawn this entity!  (E.G when using Durgzmod.)
I reinstalled multiple times, I have ulib and ulx and no other admin mods, , the only addons are Punisher, Rape Swep, Durgz, and youtube player.  I don't have ulx addons or anything.
Offline DarkPacifist
  • A fail lua scripter
Re: You do not have permission to...
« Reply #1 on: August 19, 2012, 12:17:06 pm »
1 Did you delete the ulib folder from both garrysmod/data   and   garrysmod/addons   folders?
2 Are you running other admin mods on the same account eg* assmod, exsto, sourcemod, Evolve, frosty?
This info would be a good start for getting assistance.
Edit: I see well I wish I could be more help but I'm pretty new to this as well... The only other thing I could think of is that the group handle isn't matching your client settings... if this is the case it'll work on your actual gmod account's folder but not severfolder.
« Last Edit: August 19, 2012, 08:26:14 pm by DarkPacifist »
Offline jajolt
« Reply #2 on: August 19, 2012, 12:26:50 pm »
1: No, I'll do that now.  Edit:  Didn't work.
2:  Nope.
« Last Edit: August 19, 2012, 12:38:17 pm by jajolt »
« Reply #3 on: August 21, 2012, 04:44:44 pm »
The menu uses ULX commands to do its work. I don't see how you could use one and not the other. Can you give us the console output from trying to use a command?
Offline jajolt
« Reply #5 on: August 21, 2012, 07:43:59 pm »
What command did you run that gave you that error?
Most likely, you have a conflicting addon or gamemode function preventing ULX from even seeing an admin command.
The grey on gold background error you see is NOT from ULX. (Unless Megiddo/Stick changed error messages, but, reasonably sure they didn't)
If you go into User management in XGUI, can you modify groups?
« Last Edit: August 21, 2012, 08:13:40 pm by JamminR »
Offline jajolt
« Reply #6 on: August 22, 2012, 03:19:23 pm »
No error is red... I just highlighted it.
Heres an ss of my ftp (addons folder) but I don't think these could be conflicting.
http://zhost.tk/u/d9/yeye.png
Continuation, about 5 folders:
http://zhost.tk/u/1n/nene.png
« Reply #7 on: August 22, 2012, 04:26:57 pm »
Yah that's not a ULX error. Try removing all addons but ULib/ULX and seeing if it still has the error.
