Author Topic: ULX Manage Teams?  (Read 9213 times)
Offline serfma
ULX Manage Teams?
« on: August 29, 2012, 06:48:10 pm »
I have installed ULX and ULIB from the SVN, and whenever I go to "Manage Groups", the "Manage Teams" button is grayed out. Why is this so? I'm really needing to add Teams and whatnot but there's nothing that i've found that will allow to me to manage teams. I've made myself "Owner" rank and yet it still does not allow me to do anything with Teams.
Any quick help? :/
Re: ULX Manage Teams?
« Reply #1 on: August 29, 2012, 07:47:53 pm »
The built in UTeam only supports Sandbox gamemode. If you are running any other gamemode this will be grayed out.
Offline serfma
« Reply #2 on: August 30, 2012, 08:26:34 am »
Is there no other way with ULX that I could have Prefixes/Name Colors/etc without using Sandbox? I'm running a Trouble in Terrorist Town server and of course it's grayed. I've used DarkRP before and it's worked properly before. Any other addon that could achieve Prefixes/Name Colors/Etc?
« Reply #3 on: August 30, 2012, 02:34:19 pm »
DarkRP is derived from Sandbox which is why it would work there. TTT is either derived from Base or Fretta so it won't work. The gamemode should handle teams, if not you may need to write a small addon that does it for you. It's really easy.
http://maurits.tv/data/garrysmod/wiki/wiki.garrysmod.com/index75fb.html
Offline serfma
« Reply #4 on: August 31, 2012, 10:25:54 am »
Hmph. I'll look into it once I get home. I have added multiple groups with ULX and have attempted to change the golden color names that Admins get in the scoreboard. I've added teams/group names to the cl_scoreboard.lua (If you ever take the chance to check it out) in /TerrorTown/Gamemode/. Changed the colors but yet it does not officially change them. I have a prefix addon from GMod.Org and it should work.
Other than that, thanks. :)
