Author Topic: Unknown command: ulx  (Read 4835 times)
Offline XenGaming
« on: November 01, 2012, 04:10:51 am »
Okay so, I've installed ULX and ULib to my Garrys mod addon folder, /193.0.159.73 port 27015/garrysmod/addons Screenshot: http://puu.sh/1la9I
I have myself added as an super admin: "superadmin"
      "DarkKV"         "STEAM_0:1:45933004"
I've rebooted my server, any still.. Nothing
Also I've binded my key like this just in-case anyone asks: Bind "g" "ulx menu"
Edit:
I cant rebuild the ULib because my data folder seems to be empty..
Offline iSnipeu
Re: Unknown command: ulx
« Reply #1 on: November 01, 2012, 05:27:44 am »
Are you using the SVN?, currently that is the only one that supports Garry's Mod after the massive 13 update.
ULX: https://github.com/Nayruden/Ulysses.git/trunk/ulx
ULib: https://github.com/Nayruden/Ulysses.git/trunk/ulib
« Reply #2 on: November 01, 2012, 03:12:34 pm »
Be sure to check both your client and server console output once you start the server. You should see a bunch of ulib and ulx output to the console if it is loading properly. If you don't see anything ulx/ulib related, then ULX/ULib may not be installed properly, or there could be an issue with FastDL, etc. If you see a bunch of errors, then you should post them here so we can help you figure out what may have gone wrong.
