Author Topic: Problem installing ULX  (Read 4285 times)
Offline Prentice
« on: November 12, 2012, 01:30:52 pm »
Hi,
I've uploaded ULX + Ulib to my addons folder however I seem to get a "ULX command not recognised" when I try to run any commands...
Any idea what could cause this?
Thanks
Re: Problem installing ULX
« Reply #1 on: November 12, 2012, 01:45:46 pm »
Either ULX/ULib was not placed in the right directory (./garrysmod/addons/ulx and ./garrysmod/addons/ulib), you're not running a recent version of ULX/ULib (see here: /index.php/topic,5786.0.html), or there were errors in your server console during startup.  Try checking those things first, as they're the first things I could think of off the top of my head.
Offline Prentice
« Reply #2 on: November 12, 2012, 01:55:27 pm »
I'm not getting any errors on startup, and they're definitely in the correct folder
« Reply #3 on: November 12, 2012, 02:13:25 pm »
Then most likely it's an outdated version? IIRC, the pre-gm13 addons use info.txt to denote an addon, whereas it was changed to addon.txt in gm13. I'd make sure you're hooked in via SVN as we're fixing things quite often. Or it could be some issue with FastDL, but that's an area I'm not familiar with.
Offline Prentice
« Reply #4 on: November 12, 2012, 02:37:02 pm »
It seems i downloaded it from the wrong SVN, so I deleted and redownloaded it all and it works perfectly, thanks!
« Reply #5 on: November 12, 2012, 03:29:07 pm »
No problem, glad to know you got it working!
