Author Topic: New Error  (Read 4923 times)
Offline kaytaro
New Error
« on: November 17, 2012, 03:14:47 pm »
I got this new error after updating ULX to the newest build
8:05:34 [ERROR] lua/includes/util.lua:184: attempt to index local
'object' (a boolean value)
           1. IsValid - lua/includes/util.lua:184
            2. UpdateHovered - lua/includes/modules/widget.lua:51
             3. PlayerTick - lua/includes/modules/widget.lua:91
              4. fn - lua/includes/modules/widget.lua:151
               5. unknown - addons/ulib/lua/ulib/shared/hook.lua:168
also
L 11/17/2012 - 16:51:58: Lua Error:
[ERROR] addons/ulib/lua/ulib/shared/commands.lua:1240: attempt to index local 'ply' (a number value)
  1. unknown - addons/ulib/lua/ulib/shared/commands.lua:1240
   2. unknown - lua/includes/modules/concommand.lua:69
« Last Edit: November 17, 2012, 03:16:45 pm by kaytaro »
Re: New Error
« Reply #1 on: November 17, 2012, 03:42:34 pm »
First error doesn't have anything to do with ULib or ULX.
Under what context do you get the second error?
Offline kaytaro
Re: New Error
« Reply #2 on: November 17, 2012, 03:49:15 pm »
Nm it works.. but when I look at the adverts i did a test one and i cannot remove it lol.. so its spamming
EDIT by Megiddo: Language
« Last Edit: November 17, 2012, 04:28:16 pm by Megiddo »
Re: New Error
« Reply #3 on: November 17, 2012, 04:29:36 pm »
First: Share the error you get with us trying to remove the advert.
Second: Edit the advert out by hand by going to data/ulx/adverts.txt
Keep in mind that there are a fair number of children who play gmod, and thus are on these forums. Don't say anything you wouldn't say to a stranger's children in person.
Offline iSnipeu
Re: New Error
« Reply #4 on: November 17, 2012, 06:32:44 pm »
They both look like the changelevel bug, just don't change to the same map and you should be fine.
Offline NaRyan
Re: New Error
« Reply #5 on: November 18, 2012, 07:08:59 am »
I have had those 2 errors on my server also.
The 1st one I got when I reloaded the map (known gmod bug).
The 2nd one I got when I just had 2 bots on the server and I changed to a different level (probably another gmod bug since it only does it with bots).
