Author Topic: Question about modules  (Read 4868 times)
Offline Pac
« on: November 28, 2012, 01:01:34 pm »
Hey, I got this code:
local CATEGORY_NAME = "TTT"
function ulx.ttt_respawn( calling_ply, target_plys )
local affected_plys = {}
for i = 1, #target_plys do
local v = target_plys[i]
v:SpawnForRound( true )
table.insert( affected_plys, v )
ulx.fancyLogAdmin( calling_ply, "#A respawned #T", affected_plys )
local respawn = ulx.command( CATEGORY_NAME, "ulx respawn", ulx.ttt_respawn, "!respawn" )
respawn:addParam{ type=ULib.cmds.PlayersArg }
respawn:defaultAccess( ULib.ACCESS_ADMIN )
respawn:help( "Respawns target(s)." )
function ulx.ttt_traitor( calling_ply, target_plys )
for k, v in pairs( target_plys ) do
local v = target_plys[k]
v:SetRole( ROLE_TRAITOR )
SendFullStateUpdate()
ulx.fancyLogAdmin( calling_ply, "#A turned #T into a traitor.", affected_plys )
local traitor = ulx.command( "Fun", "ulx traitor", ulx.ttt_traitor, "!traitor", true )
traitor:addParam{ type=ULib.cmds.PlayersArg }
traitor:defaultAccess( ULib.ACCESS_ADMIN )
traitor:help( "Turns target(s) into a traitor." )
function ulx.ttt_detective( calling_ply, target_plys )
v:SetRole( ROLE_DETECTIVE )
ulx.fancyLogAdmin( calling_ply, "#A turned #T into a detective.", affected_plys )
local detective = ulx.command( "Fun", "ulx detective", ulx.ttt_detective, "!detective", true )
detective:addParam{ type=ULib.cmds.PlayersArg }
detective:defaultAccess( ULib.ACCESS_ADMIN )
detective:help( "Turns target(s) into a detective." )
function ulx.ttt_innocent( calling_ply, target_plys )
v:SetRole( ROLE_INNOCENT )
ulx.fancyLogAdmin( calling_ply, "#A turned #T into an innocent.", affected_plys )
local innocent = ulx.command( "Fun", "ulx innocent", ulx.ttt_innocent, "!innocent", true )
innocent:addParam{ type=ULib.cmds.PlayersArg }
innocent:defaultAccess( ULib.ACCESS_ADMIN )
innocent:help( "Turns target(s) into an innocent." )
And it absolutely refuses to load on my server, it's located in "addons/ULX/lua/ulx/modules/sh/testy.lua" and no matter what I've done so far, it's failed and doesn't work nor show up in the console in the
// MODULE: chat.lua //
// MODULE: fun.lua //
// MODULE: menus.lua //
// MODULE: rcon.lua //
// MODULE: teleport.lua //
// MODULE: user.lua //
// MODULE: userhelp.lua //
// MODULE: util.lua //
// MODULE: vote.lua //
// end.lua //
// Load Complete! //
part
All help is appreciated, thank you. :)
Re: Question about modules
« Reply #1 on: November 28, 2012, 02:47:52 pm »
Is this a Linux server? Are the permissions set correctly on the file?
Otherwise, nothing immediately comes to mind. All files from the "sh" directory are loaded dynamically, so if one file didn't load, none of them ought to load.
« Reply #2 on: November 28, 2012, 03:58:20 pm »
Though you stated you copied it to your server's folder, make sure you did... I don't know how many times I've copied code I've worked on to my client folder, to of course, have it do nothing.
(Easy to do when running server/client from same machine for testing)
Offline Pac
« Reply #3 on: December 01, 2012, 12:45:33 pm »
Yeah it's a Linux server and yes it has been copied properly to the server
