Author Topic: Changing server Name and Password  (Read 15080 times)
Smoot
« on: December 07, 2006, 02:15:20 pm »
Got ULX working yay.
Now how do I change the server name and password for GMOD10 and hpw does one change the map?
Re: Changing server Name and Password
« Reply #1 on: December 07, 2006, 04:21:46 pm »
Best way is to set them in your server.cfg file, located in garrysmod\cfg (you probably don't have one unless you created it, there is an example file server_cfg.txt or something like that)
Look for the two paramaters, both of which can also be used in the ded. server console
hostname "my server name"
sv_password "my server password"
ULX doesn't have a command to change server and password, at least technically.
You mentioned running a dedicated server in another post.
If you've given yourself ulx rcon access, while in game you could use 'ulx rcon hostname "my server name" ' and ' ulx rcon sv_password "my server password" '
As for the map when starting from command line ded server, use +map mapname
While in game, ulx map mapname
.bsp isn't required
« Last Edit: December 07, 2006, 04:23:18 pm by JamminR »
Smoot
« Reply #2 on: December 07, 2006, 09:06:48 pm »
How does one change the rcon password it doesnt seem to work in server.cfg.  Neither does rcon_password in server console.
« Reply #3 on: December 08, 2006, 03:20:06 pm »
Odd. It should.
I have (password hidden)
   "rcon_password"         "************"
in my garrysmod/cfg/server.cfg
Are you using quotes around at least the password? In console or server.cfg?
 I could see special characters causing problems if you don't.
Quotes aren't required for the rcon_password, however, they couldn't hurt.
