Author Topic: Noclip error  (Read 7769 times)
Offline bender180
    • Benders Villa
Noclip error
« on: December 27, 2012, 08:26:48 pm »
when anyone with access tries to noclip this error appears in console and the command doesn't function
L 12/27/2012 - 23:23:47: Lua Error:
[ERROR] addons/ulib/lua/ulib/shared/player.lua:84: attempt to index local 'target' (a number value)
1. getUsers - addons/ulib/lua/ulib/shared/player.lua:84
2. parseAndValidate - addons/ulib/lua/ulib/shared/commands.lua:628
3. __fn - addons/ulib/lua/ulib/shared/commands.lua:916
4. unknown - addons/ulib/lua/ulib/shared/commands.lua:1296
5. Run - lua/includes/modules/concommand.lua:69
6. unknown - addons/ulib/lua/ulib/shared/commands.lua:1310
7. unknown - lua/includes/modules/concommand.lua:69
There are no errors on startup and this just happened out of nowhere.
Re: Noclip error
« Reply #1 on: December 29, 2012, 10:36:24 pm »
Only when noclipping and nothing else?
Offline bender180
    • Benders Villa
Re: Noclip error
« Reply #2 on: December 30, 2012, 11:53:34 am »
its a weird bug and its only for noclip you have to type out the command in chat, you cant use xgui or a bind that runs the console command.
Re: Noclip error
« Reply #3 on: January 03, 2013, 08:52:57 am »
I'd like to debug this on your server -- could you contact me on steam this evening? Search Steam friends for MegTech.
Re: Noclip error
« Reply #5 on: January 05, 2013, 08:39:16 pm »
Are you sure you copied the steamid correctly? It's sometimes easy to miss a digit or two.
If you're sure, run "ulx debuginfo" while this user is connected and paste the output here.
Offline bender180
    • Benders Villa
Re: Noclip error
« Reply #6 on: January 05, 2013, 10:41:25 pm »
here is the debug dump https://dl.dropbox.com/u/2418443/debugdump.txt
and here is a video to better show the bug http://www.youtube.com/watch?v=Qbp9-nr37ow
when the id is in the group it still doesn't give him any commands.
« Last Edit: January 05, 2013, 10:44:59 pm by bender180 »
Offline bender180
    • Benders Villa
Re: Noclip error
« Reply #7 on: January 12, 2013, 03:41:16 pm »
After updating the SVN the issue went away and he has his rank like he should.
