Author Topic: Forum ranks, and ULX jail fix/idea  (Read 5478 times)
« on: December 28, 2012, 04:06:29 am »
I think people who help out allot should be rewarded with their own rank some thing like a BAT ( http://osu.ppy.sh/wiki/Beatmap_Appreciation_Team ) rank maybe.
I remmember saying that the jail command glitched in remove triggers, and I just thought of a fix for the problem. You should have it check if the jail can be spawned by making the cage and checking if it's still there after point two seconds and if it is it makes the cage non removable, but if it's not it should give the caller an error, and freeze the player instead.
Finally the jail should have an optional teleport feature where you could have the player be moved to where you are looking and then jailed.
« Last Edit: December 28, 2012, 04:09:07 am by HeLLFox_15 »
Re: Forum ranks, and ULX jail fix/idea
« Reply #1 on: December 29, 2012, 10:38:22 pm »
I like the teleport idea, I'll add it to our list. :)
« Reply #2 on: January 03, 2013, 08:14:21 pm »
"ulx jailtp" is now live on GitHub. :D
