Author Topic: Tags  (Read 14038 times)
Offline easer7
Re: Tags
« Reply #15 on: January 08, 2013, 04:14:21 pm »
Quick question about the else/if part though.
if (SERVER) then
        AddCSLuaFile("autorun/tags.lua")
if (CLIENT) then
function Insert( pl, msg )
                local tab = {}
        if pl:IsUserGroup("headmanagement") then
                table.insert( tab, Color( 255, 0, 0, 255 ) )
                        table.insert( tab, "[Head Management] " )
                table.insert( tab, Color( 255, 255, 255, 255 ) )
                        table.insert( tab, pl:Nick() )
                        table.insert( tab, ": " )
                table.insert( tab, msg )
        elseif pl:IsUserGroup("leadmanagement") then
                        table.insert( tab, "[Lead Management] " )
        elseif pl:IsUserGroup("management") then
                        table.insert( tab, "[Management] " )
        elseif pl:IsUserGroup("leadmoderator") then
                table.insert( tab, Color( 33, 110, 252, 255 ) )
                        table.insert( tab, "[Lead Moderator] " )
        elseif pl:IsUserGroup("moderator") then
                        table.insert( tab, "[Moderator] " )
        elseif pl:IsUserGroup("premium") then
                table.insert( tab, Color( 245, 226, 20, 255 ) )
                        table.insert( tab, "[Premium] " )
        elseif pl:IsUserGroup("trusted") then
                table.insert( tab, Color( 194, 19, 153, 255 ) )
                        table.insert( tab, "[Trusted] " )
        elseif pl:IsUserGroup("supporter") then
                table.insert( tab, Color( 86, 185, 80, 255 ) )
                        table.insert( tab, "[Supporter] " )
                        table.insert( tab, "[User] " )
chat.AddText( unpack(tab) )
return true
hook.Add("OnPlayerChat", "InsertTags", Insert)
I'm getting the error: /tags.lua.lua:0
[ERROR] lua/autorun/tags.lua.lua:8: unfinished string near '"headmanagement) then'  1. unknown - lua/autorun/tags.
What is this?
Re: Tags
« Reply #16 on: January 08, 2013, 04:40:05 pm »
Try this...
btw.. do you use something like Notepad++ to edit your lua? Your tabulation is atrocious. lol
if (SERVER) then
if (CLIENT) then
local tab = {}
return true
Offline easer7
Re: Tags
« Reply #17 on: January 08, 2013, 05:04:37 pm »
I do use notepad++ =( I thought notepad++ was of the highest quality, what should I use?
Re: Tags
« Reply #18 on: January 08, 2013, 08:12:07 pm »
Notepad++ is fine. Just keep your lines together.
Also, in case you missed what MrPresident did, from your error, your missing the closing quotation mark.
'"headmanagement) then' should have been  '"headmanagement") then'
Also, why use so many table.inserts?
Table manipulation is time consuming (for any programming language, even Lua).
It would be better, optimization wise, to use this ...
table.insert( tab, Color( 255, 0, 0, 255 ) .. "[Management] " .. Color( 255, 255, 255, 255 ) .. pl:Nick() .. ": " .. msg )
elseif ...
than what you're doing currently.
Look up "lua concatenation".
Those ".." bring together many string items.
Re: Tags
« Reply #19 on: January 09, 2013, 09:15:10 am »
elseif ...
It's necessary to do it the way he currently is. The color objects are not strings, and chat.AddText wants a list of string or color objects.
Offline easer7
Re: Tags
« Reply #20 on: January 09, 2013, 04:58:30 pm »
Sorry I'm very new to this.  I've been going through the tutorials but im not done yet! :) Also, how do I get it to say |TEAM| when they talk in team chat and |DEAD| When dead players are talking? Would this work?
                if ( pl:Alive == false ) then
      table.insert( tab, Color( 255, 30, 40 ) )
      table.insert( tab, "|DEAD| " )
      if ( bTeamOnly ) then
      table.insert( tab, Color( 30, 160, 40 ) )
      table.insert( tab, "|TEAM|" )
