Author Topic: Undo Can't Target command  (Read 13864 times)
Offline TowerSheep
« on: January 07, 2013, 03:03:00 pm »
I read can't target command wrong and made it so my higher level admins cannot target the lower level admins. Is there a way to undo this?
Re: Undo Can't Target command
« Reply #1 on: January 07, 2013, 04:26:03 pm »
Unfortunately no (not without resetting all of your group permissions, anyways), but the default values are pretty simple to set up again:
<group> can_target = "!%<group above>"
So, for the default groups:
superadmin = "*"
admin = "!%superadmin"
operator = "!%admin"
user = "!%operator"
EDIT: Fixed a minor error
« Last Edit: January 08, 2013, 08:36:41 am by Stickly Man! »
Offline TowerSheep
« Reply #2 on: January 07, 2013, 09:07:04 pm »
Where is the file that the group permission values are stored?
Thanks for the helpful information!
« Reply #3 on: January 07, 2013, 09:25:18 pm »
gmod/data/Ulib/groups.txt
Offline TowerSheep
« Reply #4 on: January 12, 2013, 05:09:11 am »
I meant that file where it says who can target who. I can just do a clean install of that file correct?
« Reply #5 on: January 12, 2013, 06:58:19 am »
If in doubt, a data wipe will work. Run "ulx resettodefaults" in server console to reset everything.
« Reply #6 on: January 12, 2013, 11:33:31 am »
Same folder as I posted above, but the file is called 'users.txt'
gmod/data/Ulib/users.txt
Offline TowerSheep
« Reply #7 on: January 15, 2013, 01:15:51 pm »
Thanks guys, I got it fixed. Please lock
