Author Topic: TempAdd (v2.4) - Add a user to another group for a set amount of time  (Read 167090 times)
Offline lua_error
Re: TempAdd (v2.1) - Add a user to another group for a set amount of time
« Reply #15 on: January 27, 2013, 07:33:53 pm »
It appears that <player>:IsConnected() is only available serverside, so the code will have to be changed to adapt to that. :S
How to fix this?
« Reply #16 on: January 27, 2013, 07:42:30 pm »
How to fix this?
Wait until Mr. President has a fix, I'm afraid.
« Reply #17 on: January 27, 2013, 10:31:46 pm »
Busy busy weekend!
I'll try and remember to push and update tomorrow. I'm currently not at my workstation.
Re: TempAdd (v2.2) - Add a user to another group for a set amount of time
« Reply #18 on: January 28, 2013, 08:51:38 pm »
Update pushed.
2.2 should fix these things. Check the changelog in the first post.
« Reply #19 on: January 28, 2013, 09:25:55 pm »
Looks good, Mr. P!  8)
Offline Mesmaroth
« Reply #20 on: February 06, 2013, 09:57:14 pm »
Thanks, keep up the good work! Also going to learn LUA so I can give to the community!
Offline DeathRowDave201
« Reply #21 on: February 11, 2013, 06:47:02 am »
Hi could you see about making it possible to add users via their steamID and not just their username?
Regards,
Dave
Offline datgregofag
« Reply #22 on: February 12, 2013, 02:33:34 pm »
Hi, do you think you can make it so that its not only a certain number of min but also like hours,days,weeks,months,years etc. Thank you.
« Reply #23 on: February 12, 2013, 10:25:44 pm »
I could look at how ULX handles their string time parser. In the mean time just do the math.
1 hour = 60 minutes
1 day = 1440 minutes
1 week = 10080 minutes
1 month = 43200 minutes
1 year = 525600 minutes
« Last Edit: February 12, 2013, 10:27:25 pm by MrPresident »
Offline lua_error
« Reply #24 on: February 13, 2013, 12:11:06 am »
Will it possible to add users via SteamID?
It will be very comfortable not to wait player online.
« Reply #25 on: February 13, 2013, 10:58:36 am »
I believe there's a specific parameter (ULib.cmds.allowTimeString) you can set on your NumArg to allow it to process timestrings. So, assuming I'm not mistaken (it happens more often than you think :P), adding said parameter to the NumArg should be all you need to do. Here's the NumArg for ulx ban:
ban:addParam{ type=ULib.cmds.NumArg, hint="minutes, 0 for perma", ULib.cmds.optional, ULib.cmds.allowTimeString, min=0 }
Hope that helps! :)
Offline datgregofag
« Reply #26 on: February 13, 2013, 12:01:01 pm »
Stickly man, can you please tell me where to put that and if its in ulxtempuser.lua, can you tell me what line. THANK YOU!
« Reply #27 on: February 13, 2013, 12:53:21 pm »
Inside of ulxtempuser.lua (line 156 in the most recent update)
Replace
tempadduser:addParam{ type=ULib.cmds.NumArg, hint="Time (Minutes)" }
with
tempadduser:addParam{ type=ULib.cmds.NumArg, hint="Time (Minutes)", ULib.cmds.allowTimeString }
*Note* I haven't tested this so be weary... If this works let me know and I'll add it as an official update to the addon.
Offline datgregofag
« Reply #28 on: February 13, 2013, 04:29:23 pm »
THANK YOU THAT WORKS, i mean the  days weeks months thing, IT WORKS. But one more question, will the temporary add still work on a person if i turn server off and then back on. If it doesn't can you please work on a fix. THANK YOU!!!
« Reply #29 on: February 13, 2013, 09:51:19 pm »
Yeah, it is designed to work across server sessions.
