Author Topic: Okay so I got a few problems.  (Read 5077 times)
Offline creighmoe
« on: January 12, 2013, 01:26:43 pm »
How do I add Donators Perks? Also I have a problem with my M16. Everytime someone use the ironsights I get a Error for to many Lua errors.
Re: Okay so I got a few problems.
« Reply #1 on: January 12, 2013, 02:47:08 pm »
The problem with the M16 is something in the SWEPs lua code most likely. Are you using the default CS:S Weapons that Garry included (does he even include them anymore?) or did you install your own?
As for donator perks, there are all kinds or way to implement them. What kinds of things did you have in mind?
Offline creighmoe
« Reply #2 on: January 12, 2013, 05:25:04 pm »
I wanted to add things like a katana, skins, Snipers for the Ts and Ds, Stuff like that.
The M16 is now showing up on dead bodies as grenades instead of the m16. I just tried to change the name of it.
Offline nathan736
« Reply #3 on: January 18, 2013, 06:40:12 am »
show us code ;)
Offline creighmoe
« Reply #4 on: January 26, 2013, 04:11:45 pm »
That's the thing nathan. I only got part of the code thanks to the zm forums. As for the making it buyable in the shops or make them autospawn for donators and admins.
Offline nathan736
« Reply #5 on: January 28, 2013, 09:03:04 am »
well if you only have part of the code it will never work ;..; *Derp*
