Author Topic: AWarn 3.4 - Robust warning system  (Read 249789 times)
Offline nathan736
Re: AWarn 3.3 - Robust warning system
« Reply #30 on: January 18, 2013, 06:43:46 am »
Each entry is a separate file. If I did that, the script would have to open up each file in order until it found the the right steamid.
could you not just have a table that links the steam id with the normal  64bit steam id so the game can tell  steam id = the 64 bit one ?
ps: i don't mean steamid:0:0:533216 = 5251627321
Offline Boncey
« Reply #31 on: February 01, 2013, 12:34:11 pm »
Not working :l
« Reply #32 on: February 01, 2013, 02:00:13 pm »
Not working :l
Care to elaborate? Are you getting any errors?
Offline delagious
« Reply #33 on: February 01, 2013, 08:22:09 pm »
Not working :|
] ulx_warnkick_ban 1
] ulx_warnkick_bantime 60
] ulx_warnkick_decayrate 25
] ulx_warnkick_num 2
"ulx_warnkick_decayrate" = "25" ( def. "" )
 server_can_execute clientcmd_can_execute
 - Minutes a player needs to be connected before their warning count is decreased by 1.
] ulx_warnkick_decayrate 30
"ulx_warnkick_decayrate" = "30" ( def. "" )
] ulx warn "Mistah Mee" Test
You warned Yourself (Test)
AWarn: You were warned by (Mistah Mee) for: Test
Disconnect: Warning threshold exceeded.
So it doesn't ban as it should and it doesn't trigger on the number I set not sure if bantime works because it won't ban.
Edit#1: What I mean by not working is it isn't allowing itself to be customized. I uses the default settings it came with.
1. It kicks ALWAYS.
2. It only works after 3 warns.
3. I haven't changed the refresh rate but I imagine it's stuck at 30 minutes.
4. Haven't had the chance to see if it will use a custom ban time.
« Last Edit: February 02, 2013, 11:00:09 am by delagious »
« Reply #34 on: February 01, 2013, 10:44:47 pm »
I'll have to look into this a little more. Thanks for posting the log
Offline Boncey
« Reply #35 on: February 02, 2013, 07:50:49 am »
No errors, the plugin isn't detected, when I go !warn or 'ulx warn' it does nothing!
« Reply #36 on: February 02, 2013, 08:06:51 am »
Does it show as loaded in your server console during server startup?
What does it say in your server console when you run the command, if anything?
What does it say in your client console when you run the command? (command not found?)
My first guess, without seeing answers to those questions, would be that it's not running from your servers addons folder.
« Reply #37 on: February 02, 2013, 12:14:29 pm »
1. It kicks ALWAYS.
Try changing the configurations using the console variables and then changing map or restarting your server. It may be an issue with how the con variables are storing and retrieving info. Also make sure you are making those changes on the server. Don't attempt to run the console commands on your client, even if you are a superadmin.
Offline delagious
« Reply #38 on: February 02, 2013, 01:31:45 pm »
No response from the server (this may be an invalid command)
"ulx_warnkick_bantime" = "60" ( def. "" )
game clientcmd_can_execute
- How long in minutes a player is banned if ulx_warkick_ban is set to 1.
"ulx_warnkick_num" = "2" ( def. "" )
- Number of warnings a player needs before they are kicked/banned.
"ulx_warnkick_ban" = "1" ( def. "" )
- If this is set to 1, the script will issue a temp ban instead of a kick.
Each time I tried changing a value I got "No response from the server (this may be an invalid command)" but
when I checked what the value was set to it returned the values I had set earlier through my client.
Would changing these values directly from the "warn.lua" file work?
Side note: Even though console returned an error these values now work...
« Reply #39 on: February 03, 2013, 02:34:50 pm »
It's odd that it returns an error. The reason you need to do it from the server is because if you do it from the client it will change the value clientside as the convars are shared I believe.The script only reads from the serverside ones though.
So is everything working as intended now (even with the errors when run through the server console)?
Offline delagious
« Reply #40 on: February 03, 2013, 06:37:26 pm »
Yes it works just fine with the new settings I ran through the server console but it also gives me the weird errors after I change a value.
It now bans as it should and after the right amount of warns and for the correct time.
Offline RoundEye
« Reply #41 on: February 26, 2013, 08:03:00 pm »
Sweet!
« Reply #42 on: February 27, 2013, 10:46:05 pm »
I hope youre still monitoring this thread. Could you copy and paste the errors you are getting?
Offline delagious
« Reply #43 on: February 28, 2013, 07:27:41 pm »
when I type the command "ulx_warnkick_num" I get this response in console:
"ulx_warnkick_num" = "4" ( def. "" )
but when I type "ulx_warnkick_num 5" I get this response.
No response from the server (this may be an invalid command)even though I get an error the value is changed from 4 to 5. That error is what I get
for when I try to change any of the values whether it be any of these:
  • ulx_warnkick_num
  • ulx_warnkick_decayrate
  • ulx_warnkick_ban
  • ulx_warnkick_bantime
« Reply #44 on: February 28, 2013, 07:52:22 pm »
You know you're supposed to be typing those on the server console or rcon, right?
Are you?
