Author Topic: AWarn 3.4 - Robust warning system  (Read 249789 times)
Offline MikZeR
Re: AWarn 3.4 - Robust warning system
« Reply #75 on: October 20, 2013, 02:37:36 am »
Awesome addon, however, I can't get it working. :/
When I put it into my addons folder nothing happens, so I tried opening up the lua file and putting everything in ULX-folder as a module, but that's not working for me either.
Do you have any idea what I can do to make it work?
Thank you in advance! :)
Offline xLiaMz
« Reply #76 on: October 20, 2013, 07:17:49 am »
Can I give certain groups the permissions to use this? for e.g. Moderator
also is the plugin updated to 2.5 DarkRP?
« Reply #77 on: October 20, 2013, 08:50:44 am »
Basic troubleshooting of addons.
Make sure you didn't end up with too many folders in addons. /addons/awarn(1)/awarn , where 1 would have no files in it but the additional awarn folder.
As for merging it with ULX folders, that alone can cause troubleshooting issues, as you end up with files scattered everywhere within ULX, and may be missing some.
Are you getting any errors on your server during startup related to the awarn folder?
Did you accidentally place it on your client folders instead of your server?
Too many other minor troubleshooting steps to list.
We know it works for majority, the issue is likely something simple on your end.
Use ulx groupallow to give any of the awarn commands you want your moderators to have.
There are several commands related to awarn. See the release first post to determine what you want moderators to have.
No idea. We don't support or program compatibility with DarkRP.
It's compatible with versions of ULX as of this post.
« Last Edit: October 20, 2013, 08:54:31 am by JamminR »
« Reply #78 on: October 20, 2013, 12:13:19 pm »
There is no reason this shouldn't be compatible with DarkRP. There are many people out there who run this on DarkRP servers.
Let me know if you are having any issues.
Offline lostmymind
« Reply #79 on: October 22, 2013, 01:18:55 pm »
Hello!
Is there any way to get the command ulx seewarns <player> to make a xgui.window and shows you ingame and not in the console, simply just a window showing the records of the players warnings, then you simply just close it?
Thank you!
« Reply #80 on: October 22, 2013, 01:22:01 pm »
Not easily. I was thinking of adding this, but just haven't got around to it yet.
Offline rainbow Dash
    • Friendship is Gaming
« Reply #81 on: November 03, 2013, 01:16:21 am »
I know someone who has manifested a derma menu that displays a persons warnings. The issue is he never shared the code with me, nor told me anything about it.
Uhm, whats a signature?
Offline TheSabreSlicer
« Reply #82 on: December 10, 2013, 07:44:41 pm »
Hey,
For some reason when I drop this in my addons folder and restart my server, nothing happens.
I get unknown command when I try any commands.
« Reply #83 on: December 10, 2013, 11:36:20 pm »
Check your server console on start-up. Are there any errors?
Next, make sure you installed it correctly. Inside of the folder you put inside of your addons folder make sure there is a file called addon.txt
« Reply #84 on: December 11, 2013, 06:31:55 am »
I think I fixed it, Linux does not recognize folders with capital letters, maybe something you should change on the download.
« Reply #85 on: December 11, 2013, 07:02:20 am »
Ahh, yeah. I think I already did this for another of my releases. I've never used linux before, so I'm lost to some of its intricacies sometimes.
« Reply #86 on: December 11, 2013, 11:43:46 am »
FYI - Linux understands mixed case just fine. It's just that Gmod (or perhaps Source server) on linux, to keep things 'easier' I'd guess, will only look for lowercase.
This
this
tHis
THIS
ThIs
In majority of linux file systems, the above would be 5 separate files or directories.
In Windows, as you're experienced with, it's only one.
Just remember that linux file systems are usually like lua function and variable names, case-sensitive, and for gmod, try to always use lower case file/folders.. :)
Offline Eccid
    • Terror Abound! Steam Group
« Reply #87 on: December 13, 2013, 12:16:08 pm »
I was still getting the console errors when warning from the console, so I made different check that seems to be working fine for me. I replaced lines 62 and 63 with this:
  1.         if calling_ply:IsValid() then
  2.                 local safenick = calling_ply:Nick()
  3.         else
  4.                 safenick = "Console"
  5.         end
Now it seems to be running smoothly for me. Hope this helps anyone else.
Offline orrila
« Reply #88 on: December 15, 2013, 02:02:46 pm »
Hi Guys
When trying to delete all warnings from myself, I get an error and it doesnt work. Sorry, I cannot get this error from console yet as I cannot access gmod atm. I look in the data folder in the Ulx place with warnings, but there is nothing there but when I try to display warnings it still shows the warning I self-issued.
Anyone else getting this?
If you need console command, I can get it later when I can access gmod again.
EDIT:
Console code when warning myself with the reason test:
[ERROR] addons/ulx_warn/lua/ulx/modules/sh/warn.lua:129: attempt to concatenate local 'SID' (a nil value)
  1. WarningSave - addons/ulx_warn/lua/ulx/modules/sh/warn.lua:129
   2. unknown - addons/ulx_warn/lua/ulx/modules/sh/warn.lua:106
Timer Failed! [ULX_DecayTimer][@addons/ulx_warn/lua/ulx/modules/sh/warn.lua (line 112)]
ANd this when trying to delete all warns for myself:
[ERROR] addons/ulx_warn/lua/ulx/modules/sh/warn.lua:248: attempt to concatenate local 'SID' (a nil value)
  1. call - addons/ulx_warn/lua/ulx/modules/sh/warn.lua:248
   2. __fn - addons/ulib/lua/ulib/shared/commands.lua:943
    3. unknown - addons/ulib/lua/ulib/shared/commands.lua:1296
     4. unknown - lua/includes/modules/concommand.lua:69
THanks
Orrila
« Last Edit: December 15, 2013, 03:28:31 pm by orrila »
Offline cortez (Mr. T. FOO!)
« Reply #89 on: December 21, 2013, 06:22:54 pm »
I don't know if this is a problem that is caused by your addon, but since I added it my console has started spamming "Decay timer running" like 8 times a second. A quick google search brought me to an unresolved facepunch thread that was unrelated to this addon but it seems like a little too much of a coincidence to me. Help would be appreciated, I don't want to have to remove this addon over this.
