Author Topic: AAFK V_3.1 : Anti-AFK system for Garry's Mod  (Read 246969 times)
Re: AAFK V_3.1 : Anti-AFK system for Garry's Mod
« Reply #105 on: March 28, 2015, 11:31:02 am »
You're not getting kicked or warned because you are an admin and you have ignore admins turned on.
Offline Belly136
« Reply #106 on: March 28, 2015, 12:13:53 pm »
I don't know what i'm typing anymore. I have it off not on  :-\
« Last Edit: March 30, 2015, 01:44:36 am by Belly136 »
Offline Belly136
« Reply #107 on: March 30, 2015, 01:44:05 am »
Anyone?
« Reply #108 on: March 30, 2015, 02:20:13 am »
This plugin is pretty old. I wouldn't be surprised if something either in your gamemode or in garrysmod is preventing players from being flagged as AFK.
Is it just you or all players on your server?
Offline Belly136
« Reply #109 on: March 30, 2015, 10:43:23 pm »
Well the problem is i'm just testing few scripts so i'm doing all alone. I'll ask friend and i'll also try on different gamemode.
Edit: Nevermind. I've completely reinstalled my server and it's working fine now. How can i double time before player gets kicked if he's a donator?
« Last Edit: March 30, 2015, 11:56:21 pm by Belly136 »
Offline Bryantdl7
« Reply #110 on: March 31, 2015, 04:53:24 am »
feel free to correct me if im wrong but i dont believe there is the ability to do that currently
Offline Belly136
« Reply #111 on: April 01, 2015, 03:22:02 am »
Ok so i guess aafk isn't working on prop hunt because i've tried everything. I've tested it on clean ph gamemode and it wasn't working. But on one i used before it worked but it was always flagging me as afk after 2 minutes(when it is actually set to 10 and ignore admins set to 1).
Offline Nekomi
  • Nya~
« Reply #112 on: October 18, 2015, 07:35:59 am »
Sorry to bumps this thread, (you can delete my post if needed) but i've applied theses lines into my console, but as SuperAdmin, i still get kicked for afk.
Anyone have encountered the same problem ?
Otherwise, i'm kinda interessed by an addition on this plugin, i mean, having a text above the player ead and it says "AFK".
« Reply #113 on: October 18, 2015, 11:50:08 am »
To my knowledge, this looks for "superadmin" not "SuperAdmin", and, you'd have to have the setting for ignore admins enabled.
Offline Nekomi
  • Nya~
« Reply #114 on: October 24, 2015, 04:44:06 pm »
Fixed, now i'm looking to add my moderators to the lua, but if i replace IsAdmin by pl:IsUserGroup("mod")
Will admins get kicked ?
« Reply #115 on: October 25, 2015, 09:45:49 am »
yes, you would need to replace it with:
if pl:IsAdmin() then
with
if pl:IsAdmin() or pl:IsUserGroup("mod") then
Offline Nekomi
  • Nya~
« Reply #116 on: October 25, 2015, 11:31:21 am »
well, i forgot one, so if i do
if pl:IsAdmin() or pl:IsUserGroup("mod") or pl:IsUserGroup("NivMax") or pl:IsUserGroup("NivMax") and GetConVarNumber( "ulx_afk_ignoreadmins" ) == 1 then
this will work ?
« Last Edit: October 25, 2015, 11:34:27 am by Nekomi »
« Reply #117 on: October 25, 2015, 12:21:04 pm »
For this, you would need to close the first set of arguments in parenthesis.
if ( pl:IsAdmin() or pl:IsUserGroup("mod") or pl:IsUserGroup("NivMax") or pl:IsUserGroup("NivMax") ) and GetConVarNumber( "ulx_afk_ignoreadmins" ) == 1 then
Offline ProxyRP
« Reply #118 on: January 23, 2016, 06:01:57 pm »
Thank you so much, this will be very useful.
Offline Jamster
  • Oh... Hi :)
    • http://2swag4you.net
« Reply #119 on: April 05, 2016, 08:56:09 am »
Is there someway to echo the AFK only to staff and the person directly?
So it doesn't come in chat for other users, at all, even as a "(Someone)"
