Author Topic: AAFK V_3.1 : Anti-AFK system for Garry's Mod  (Read 246969 times)
Offline The1stLieutenant
Re: AAFK V_3.1 : Anti-AFK system for Garry's Mod
« Reply #15 on: May 30, 2013, 07:15:21 am »
I'd hate to ask, but I must be missing something, I can't seem to find where I get the ULX_AFK folder anywhere.
If someone could help me, that'd be great.
« Reply #16 on: May 30, 2013, 07:45:28 am »
It's the attached file in the main post.
ULX_AFK.zip
Make sure that when you extract it, it stays in a folder called ULX_AFK. Inside that folder should be the addon.txt file along with a couple of folders.
« Reply #17 on: May 30, 2013, 09:29:28 am »
:/ I can't believe I missed that. Thanks!
« Reply #18 on: May 31, 2013, 12:26:16 pm »
Wow, I tried it out, and it was better than I expected to be. I do have a couple suggestions though, I don't know how hard this would be, but would it be possible to code it so it ignore's certain groups? say if I wanted to make my own group called: cool guys, but they don't inherit from admin, so they're not immune to anti-AFK. But if I went into the lua folder, and changed a few things, such as: groups this affects, and say "cool guys" when I would save it, it will no longer affect that group.
My second suggestion is; you could put something in where it does ignore admins, and after a set of time it will give them the tag of AFK, but the auto-kick will ignore them. Say if there's a server full, and I need to kick an AFK for a friend/server owner. there could be an AFK admin/moderator, but since they're immune to anti-AFK I can't tell if he's AFK or not. if you were to do the above, then we could easily tell if ANYONE on the server is AFK, and if we really needed to, we would kick an admin/moderator for someone else.
That's all I have for now. If I have any other suggestions, I'll post them here.
Thanks for reading.
Offline Agentmass
« Reply #19 on: July 08, 2013, 10:35:41 pm »
I know this thread is kind of old, but would it be possible to add a chat command that would allow you to set your self afk? Like !afk.
Offline Epsilon
« Reply #20 on: July 15, 2013, 10:49:15 pm »
I also seem to be having trouble with exempting admins from the auto-kick. For some reason it doesn't seem to recognize them as admins and so it kicks them even when ulx_afk_ignoreadmins is set to 1.
« Reply #21 on: July 16, 2013, 12:14:42 pm »
How are your admins defined in ULX? This only ignores players who register on IsAdmin(). So this would be: superadmin, admin, and any other group that inherits admin.
Offline Eccid
    • Terror Abound! Steam Group
« Reply #22 on: July 17, 2013, 10:16:20 am »
Is there a way I can remove the chat command for this? I've been wanting to set up something that handles users wanting to go afk differently, but I can't find anywhere in this where the command is set up, let alone how to remove it.
« Reply #23 on: July 17, 2013, 01:34:00 pm »
There isn't a chat command for this. All this addon does is monitor a player and auto detect if they're afk.
Offline Eccid
« Reply #24 on: July 18, 2013, 06:56:34 am »
I feel silly. I found where the problem was, apparently it was part of another plugin I thought I'd removed.
Offline newbchu
« Reply #25 on: November 22, 2013, 12:08:07 am »
What if you already have ULX do you put it in the ulx folder or just the addon folder?
« Reply #26 on: November 22, 2013, 01:52:41 pm »
It's an addon, goes in addons folder.
(Good tip - if when you open a release zip file, and there is an addon.txt file inside the first folder of the zip...good chances are it's an addon.)
Offline orrila
« Reply #27 on: December 15, 2013, 02:05:02 pm »
Hi Guys
This is giving me errors (in single player, but its when I start, nothing loads up to do with this at all). Im not sure if it still works or not though, (nothing to test it on in SP). No access to gmod for me atm, so if you need the console errors I can get in a few days.
EDIT:
This was the errors in the console.
[ERROR] addons/ulx_afk/lua/ulx/modules/sh/aafk.lua:65: attempt to concatenate local 'PID' (a nil value)
  1. fn - addons/ulx_afk/lua/ulx/modules/sh/aafk.lua:65
   2. Call - addons/ulib/lua/ulib/shared/hook.lua:183
    3. unknown - addons/ulib/lua/ulib/init.lua:93
     4. unknown - lua/includes/modules/concommand.lua:69
Thanks
Orrila
« Last Edit: December 15, 2013, 03:21:26 pm by orrila »
Offline syn.
  • Lua Padawan
    • SynGaming
« Reply #28 on: January 24, 2014, 05:14:56 pm »
I love this thanks pres!
Lua Student
"The more you understand, the crazier you get."
« Reply #29 on: January 24, 2014, 05:47:15 pm »
seems legit.
