Author Topic: ULX User mysql  (Read 12898 times)
Offline CheesyViking
ULX User mysql
« on: January 18, 2013, 02:05:51 am »
Hey I'm making a auto donation system with PayPal IPN system and I was wondering how to give permissions to the users automatically is there a way I can get a mysql table for them or something like that?
Re: ULX User mysql
« Reply #1 on: January 18, 2013, 06:13:32 am »
check around in the Developer's Corner forum and releases. I know there are a few examples of MySQL authentication floating around out there. (I put them there)
Re: ULX User mysql
« Reply #2 on: January 18, 2013, 05:56:17 pm »
Hey, thanks for the fast reply sorry I wasn't on but is this the thing?
/index.php/topic,5188.0.html
Re: ULX User mysql
« Reply #3 on: January 18, 2013, 06:07:17 pm »
The module download links don't work what do I do?
Re: ULX User mysql
« Reply #4 on: January 19, 2013, 04:17:49 am »
How versed are you with lua?
Re: ULX User mysql
« Reply #5 on: January 19, 2013, 04:00:41 pm »
Not very fond...
Re: ULX User mysql
« Reply #6 on: January 19, 2013, 05:03:51 pm »
The reason I asked is because I have a working version:
require("mysqloo")
G4PSQL = {}
local DATABASE_HOST = "127.0.0.1"
local DATABASE_PORT = 3306
local DATABASE_NAME = "g4padmin"
local DATABASE_USERNAME = "root"
local DATABASE_PASSWORD = ""
local DATABSE_TABLE = "userauth"
function G4PSQL_Init()
G4PSQL_ConnectToDatabase()
timer.Simple(60, G4PSQL_Init )
hook.Add( "Initialize", "G4PSQL_Init", G4PSQL_Init )
function G4PSQL_Format( str )
if not str then return "NULL" end
return string.format( "%q", str )
function Escape( str )
if not G4PSQL.db then
Msg( "Not connected to DB.\n" )
return
if not str then return end
local esc = G4PSQL.db:escape( str )
if not esc then
return nil
return esc
function G4PSQL_ConnectToDatabase()
G4PSQL.db = mysqloo.connect( "127.0.0.1", "root", "", "g4padmin", 3306 )
G4PSQL.db:connect()
function G4PSQL_PlayerAuthDB( ply )
if G4PSQL.db == nil then
if G4PSQL.db:status() == 0 then
local sid = ply:SteamID()
print("Checking for: " .. Escape( sid ) )
local q1 = G4PSQL.db:query("SELECT * FROM " ..DATABSE_TABLE.. " WHERE steamid = "..G4PSQL_Format( Escape( sid ) ).."")
function q1:onSuccess( data )
if data[1] then
--PrintTable(data)
ply.steamid = data[1]["steamid"]
ply.name = data[1]["pname"]
ply.group = data[1]["pgroup"]
ply.banned = data[1]["banned"]
ply.lastplayed = data[1]["lastplayed"]
--ServerLog("/////PLAYER DATA FOUND/////" .. "\n")
--ServerLog("Name: " .. ply.name .. "\n")
--ServerLog("SteamID: " .. ply.steamid .. "\n")
--ServerLog("Group: " .. ply.group .. "\n")
--ServerLog("Last Played: " .. ply.lastplayed .. "\n")
--ServerLog("Banned?: " .. ply.banned .. "\n")
--ServerLog("///////////////////////////" .. "\n")
if ply.name != ply:Nick() then
--ServerLog( "Updating name for player: " ..ply:Nick() .. "\n" )
local q2 = G4PSQL.db:query("UPDATE " ..DATABSE_TABLE.. " SET pname="..G4PSQL_Format( Escape( ply:Nick() ) ) .. " WHERE steamid=" ..G4PSQL_Format( Escape( sid ) ) )
function q2:onSuccess( data2 )
--ServerLog( "Name updated sucessfully!\n" )
function q2:onError( Q, E )
ServerLog( "ERROR!!! " .. Q .. "\n" )
ServerLog( "ERROR!!! " .. E .. "\n" )
q2:start()
--ServerLog( "AUTHING PLAYER: " ..ply:Nick().. " in group (" ..ply.group..")." .. "\n" )
ULib.ucl.addUser( ply:SteamID(), _, _, ply.group )
SGS_SetUpTeams(ply)
local q4 = G4PSQL.db:query("UPDATE " ..DATABSE_TABLE.. " SET lastplayed="..G4PSQL_Format( Escape( tostring(os.date("%y/%m/%d")) ) ) .. " WHERE steamid=" ..G4PSQL_Format( Escape( sid ) ) )
function q4:onSuccess( data4 )
--ServerLog( "User Data (lastplayed) updated sucessfully!\n" )
function q4:onError( Q, E )
q4:start()
if string.upper(ply.banned) == "TRUE" then
ULib.kick( ply, "BANNED! Visit our website at www.g4p.org to dispute this ban." )
ULib.tsay(ply, "Welcome back " ..ply:Nick().. ", you have been authenticated as: " ..ply.group..".", true)
ply:Spawn()
--print("No Entry Found")
--ServerLog("No Results Found ... Creating Entry\n")
local q3 = G4PSQL.db:query( "INSERT INTO " ..DATABSE_TABLE.. " ( steamid, pname, pgroup, lastplayed, banned ) VALUES( " ..G4PSQL_Format( Escape( sid ) ) .. ", " ..G4PSQL_Format( Escape( ply:Nick() ) ) .. ", " ..G4PSQL_Format( Escape( "user" ) ) .. ", " ..G4PSQL_Format( Escape( tostring(os.date("%y/%m/%d")) ) ) .. ", " ..G4PSQL_Format( Escape( "FALSE" ) ).. " )" )
function q3:onSuccess( data3 )
--ServerLog( "Entry added sucessfully!\n" )
function q3:onError( Q, E )
q3:start()
ply:Spawn()
q1:start()
G4PSQL_RetryAuth( ply )
return
hook.Add( "PlayerAuthed", "G4PSQL_PlayerAuthDB", G4PSQL_PlayerAuthDB )
function G4PSQL_RetryAuth( ply )
if not ply.retries then ply.retries = 3 end
if ply.retries > 0 then
ply.retries = ply.retries - 1
--ServerLog("DATABASE NOT CONNECTED - RETRYING (" .. tostring(ply.retries) .. " retries left)" .. "\n")
timer.Simple(2, function() G4PSQL_PlayerAuthDB( ply ) end)
ServerLog( "FALLBACK AUTHENTICATION... DATABASE CAN NOT BE CONNECTED TO\n" )
--ServerLog( "AUTHING PLAYER: " ..ply:Nick().. " in group (user)." .. "\n" )
ULib.ucl.addUser( ply:SteamID(), _, _, "user" )
SGS_SetUpTeams(ply)
ply:Spawn()
function G4PSQL_ChangeGroup( ply, cmd, args )
local sid = args[1]
local group = tostring(string.lower(args[2]))
if !IsValid( ply ) or ply:IsUserGroup("superadmin") then
if #args != 2 then
SGS_SendMessage(ply, "Wrong number of arguements!")
return
if (string.sub(sid, 1, 5) == "STEAM") then
sid = sid
qtype = 1
if IsValid(ULib.getUser(sid)) then
sid = ULib.getUser(sid)
qtype = 2
if not sid then
SGS_SendMessage(ply, "User not found!")
return
return
local gcheck = false
for k, v in pairs(ULib.ucl.groups) do
if group == k then
SGS_SendMessage(ply, "Checking " ..group.. " against " .. k)
gcheck = true
break
if gcheck == false then
SGS_SendMessage(ply, "Group doesn't exist!")
return
if qtype == 1 then
if data[1] then
SGS_SendMessage(ply, "Updating group for steamID: (" ..sid .. ")")
local q2 = G4PSQL.db:query("UPDATE " ..DATABSE_TABLE.. " SET pgroup="..G4PSQL_Format( Escape( group ) ) .. " WHERE steamid=" ..G4PSQL_Format( Escape( sid ) ) )
SGS_SendMessage(ply, "Player (" .. sid .. ") Group Changed!")
q2:start()
SGS_SendMessage(ply, "No Entry Found")
SGS_SendMessage(ply, "No Results Found ... Creating Entry")
local q3 = G4PSQL.db:query( "INSERT INTO " ..DATABSE_TABLE.. " ( steamid, pname, pgroup, lastplayed, banned ) VALUES( " ..G4PSQL_Format( Escape( sid ) ) .. ", " ..G4PSQL_Format( Escape( "ADMIN ENTERED" ) ) .. ", " .. G4PSQL_Format( Escape( group ) ) .. ", " ..G4PSQL_Format( Escape( tostring("NEVER") ) ) .. ", " ..G4PSQL_Format( Escape( "FALSE" ) ).. " )" )
SGS_SendMessage(ply, "Entry added sucessfully!")
q3:start()
q1:start()
local q1 = G4PSQL.db:query("SELECT * FROM " ..DATABSE_TABLE.. " WHERE steamid = "..G4PSQL_Format( Escape( sid:SteamID() ) ).."")
if data[1] then
SGS_SendMessage(ply, "Updating group for player: " ..sid:Nick())
local q2 = G4PSQL.db:query("UPDATE " ..DATABSE_TABLE.. " SET pgroup="..G4PSQL_Format( Escape( group ) ) .. " WHERE steamid=" ..G4PSQL_Format( Escape( sid:SteamID() ) ) )
SGS_SendMessage(ply, "Player Group Changed!")
ULib.ucl.addUser( sid:SteamID(), _, _, group )
SGS_SetUpTeams(sid)
q2:start()
local q3 = G4PSQL.db:query( "INSERT INTO " ..DATABSE_TABLE.. " ( steamid, pname, pgroup, lastplayed, banned ) VALUES( " ..G4PSQL_Format( Escape( sid:SteamID() ) ) .. ", " ..G4PSQL_Format( Escape( "ADMIN ENTERED" ) ) .. ", " .. G4PSQL_Format( Escape( group ) ) .. ", " ..G4PSQL_Format( Escape( tostring("NEVER") ) ) .. ", " ..G4PSQL_Format( Escape( "FALSE" ) ).. " )" )
q3:start()
q1:start()
SGS_SendMessage(ply, "DATABASE NOT CONNECTED PLEASE TRY AGAIN!")
SGS_SendMessage(ply, "This command is reserved for administrators only!")
concommand.Add( "g4p_setgroup", G4PSQL_ChangeGroup)
function G4PSQL_Ban( ply, cmd, args )
local sid = args[1]
local reason = args[2]
local badmin = "NONE"
local baid = "NONE"
if !IsValid( ply ) or ply:IsAdmin() then
if IsValid(ply) then
badmin = ply:Nick()
bacolor = team.GetColor(ply:Team())
baid = ply:SteamID()
badmin = "(Console)"
bacolor = Color(80,80,80,255)
baid = "(Console)"
if #args != 2 then
SGS_SendMessage(ply, "Wrong number of arguements! Be sure to include the name/steamID and a reason. Also be sure the reason is in QUOTES.")
return
sid = sid
qtype = 1
qtype = 2
if not sid then
return
return
if qtype == 2 then
if data[1] then
SGS_SendMessage(ply, "Banning player: " ..sid:Nick())
local q2 = G4PSQL.db:query("UPDATE " ..DATABSE_TABLE.. " SET banned=" .. G4PSQL_Format( Escape( "TRUE" ) ) .. ", badmin=" .. G4PSQL_Format( Escape( baid ) ) .. ", breason=" .. G4PSQL_Format( Escape( reason ) ) .. " WHERE steamid=" ..G4PSQL_Format( Escape( sid:SteamID() ) ) )
SGS_SendMessage(ply, "Player Banned for " ..reason.."!")
ULib.tsayColor(_, 1, Color(0,0,0,255), "(", Color(255,0,0,255), sid:Nick(), Color(0,0,0,255), ") ", Color(255,255,255,255), "was globally banned by ", bacolor, badmin, Color(255,255,255,255), " for ", Color(0,0,0,255), reason, Color(255,255,255,255), ".")
ULib.kick( sid, "BANNED! Visit our website at www.g4p.org to dispute this ban."  )
q2:start()
local q3 = G4PSQL.db:query( "INSERT INTO " ..DATABSE_TABLE.. " ( steamid, pname, pgroup, lastplayed, banned, badmin, breason ) VALUES( " ..G4PSQL_Format( Escape( sid:SteamID() ) ) .. ", " ..G4PSQL_Format( Escape( "ADMIN ENTERED" ) ) .. ", " .. G4PSQL_Format( Escape( "user" ) ) .. ", " ..G4PSQL_Format( Escape( tostring("NEVER") ) ) .. ", " ..G4PSQL_Format( Escape( "TRUE" ) ).. ", " ..G4PSQL_Format( Escape( "NONE" ) ).. ", " ..G4PSQL_Format( Escape( reason ) ).." )" )
ULib.kick( sid:SteamID(), "BANNED! Visit our website at www.g4p.org to dispute this ban."  )
q3:start()
q1:start()
if data[1] then
SGS_SendMessage(ply, "Banning SteamID: " ..sid)
local q2 = G4PSQL.db:query("UPDATE " ..DATABSE_TABLE.. " SET banned=" .. G4PSQL_Format( Escape( "TRUE" ) ) .. ", badmin=" .. G4PSQL_Format( Escape( baid ) ) .. ", breason=" .. G4PSQL_Format( Escape( reason ) ) .. " WHERE steamid=" ..G4PSQL_Format( Escape( sid ) ) )
SGS_SendMessage(ply, "SteamID (" .. sid .. ") Banned for " ..reason.."!")
ULib.tsayColor(_, 1, Color(0,0,0,255), "(", Color(255,0,0,255), sid, Color(0,0,0,255), ") ", Color(255,255,255,255), "was globally banned by ", bacolor, badmin, Color(255,255,255,255), " for ", Color(0,0,0,255), reason, Color(255,255,255,255), ".")
q2:start()
local q3 = G4PSQL.db:query( "INSERT INTO " ..DATABSE_TABLE.. " ( steamid, pname, pgroup, lastplayed, banned, badmin, breason ) VALUES( " ..G4PSQL_Format( Escape( sid ) ) .. ", " ..G4PSQL_Format( Escape( "ADMIN ENTERED" ) ) .. ", " .. G4PSQL_Format( Escape( "user" ) ) .. ", " ..G4PSQL_Format( Escape( tostring("NEVER") ) ) .. ", " ..G4PSQL_Format( Escape( "TRUE" ) ).. ", " ..G4PSQL_Format( Escape( "NONE" ) ).. ", " ..G4PSQL_Format( Escape( reason ) ).. " )" )
q3:start()
q1:start()
concommand.Add( "g4p_ban", G4PSQL_Ban)
function G4PSQL_UnBan( ply, cmd, args )
local sid = args[1]
banmin = "NONE"
bacolor = Color(255,255,255,255)
badmin = ply:Nick()
if #args != 1 then
if data[1] then
if data[1]["banned"] == "TRUE" then
SGS_SendMessage(ply, "UnBanning SteamID: (" ..sid .. ")")
local q2 = G4PSQL.db:query("UPDATE " ..DATABSE_TABLE.. " SET banned="..G4PSQL_Format( Escape( "FALSE" ) ) .. " WHERE steamid=" ..G4PSQL_Format( Escape( sid ) ) )
ULib.tsayColor(_, 1, Color(0,0,0,255), "(", Color(255,0,0,255), sid, Color(0,0,0,255), ") ", Color(255,255,255,255), "was unbanned by ", bacolor, badmin, Color(255,255,255,255), ".")
SGS_SendMessage(ply, "SteamID (" .. sid .. ") Unbanned!")
q2:start()
SGS_SendMessage(ply, "Player Found... but player isn't currently banned...")
SGS_SendMessage(ply, "Couldn't find SteamID: " .. sid)
q1:start()
concommand.Add( "g4p_unban", G4PSQL_UnBan)
But you will need to do some modifications to make it work for you. There it is if you want to try your hand at it.
It uses MySQLOO, you can find it on Facepunch.
Re: ULX User mysql
« Reply #7 on: January 19, 2013, 07:40:31 pm »
I've been looking for a nice new database server to store my stolen important data.
Thanks for the code!
:P
(Yes, I know...I'm joking)
Offline krooks
  • I don't like video games.
    • Diamond Krooks
Re: ULX User mysql
« Reply #8 on: January 20, 2013, 09:25:35 am »
Wow thanks a lot Mr President, that can be handy for so much!
Just by glancing over it, it looks like it's a lot bigger than just moving a person to a group. It actually handles and manages groups, bans, etc. Very cool!
My TTT server. Join the fun!
Re: ULX User mysql
« Reply #9 on: January 20, 2013, 12:17:49 pm »
:P
Good luck trying to access it from off the local machine though. :P
Offline krooks
    • Diamond Krooks
Re: ULX User mysql
« Reply #10 on: March 03, 2013, 10:56:14 pm »
Alright, so I've been working on my first major project, creating a donation system from scratch. It's pretty much done, and I used your code above to connect to my DB, and retrieve the donation amount for a connecting player. But now I need to know, what would be the best practice for retaining that amount on each connected player server-side, and retrieving it from different scripts? Do I need to set up a table or a variable, or do I save it to their pdata? I really struggle to understand this part of gmod lua.
I don't need help with how to do these things, I just need help with how to properly store and retrieve the information. I'd like to do things like build in donor perks, and display donation status on my scoreboard, etc. So I would be calling this information from multiple scripts.
Thanks!
Offline krooks
    • Diamond Krooks
Re: ULX User mysql
« Reply #11 on: March 04, 2013, 06:11:31 pm »
Ok, so I've found that this data is being stored locally (thanks stickly for the tips), but only server-side.
I'm having trouble sending the data gathered from the db to client side of things.
Anyone care to show how it's done? Thanks
Offline krooks
    • Diamond Krooks
Re: ULX User mysql
« Reply #12 on: March 05, 2013, 07:37:59 am »
Stickly pointed me toward
function ULib.clientRPC( plys,
fn,
But the documentation lacks any examples, and it's hard for me to grasp exactly how to use it, and what it actually does.
Could anyone write a quick and dirty example of this in use, both on the client and server side? Doesn't even have to be relevant to my original question.
Or better yet, point me to where this is used in an existing script.
Other people have told me to use net but that is also confusing with insufficient documentation (for me).
Basically I have a working script, but have hit a brick wall in transferring data between client and server.
« Last Edit: March 05, 2013, 07:39:47 am by krooks »
Re: ULX User mysql
« Reply #13 on: March 05, 2013, 02:27:56 pm »
Stickly uses the heck out of it for XGUI menu info updates.
But, more simple examples within ULX.
lua/ulx/modules/sh/user.lua
function ulx.usermanagementhelp( calling_ply )
if calling_ply:IsValid() then
ULib.clientRPC( calling_ply, "ulx.showUserHelp" )
ulx.showUserHelp()
local usermanagementhelp = ulx.command( CATEGORY_NAME, "ulx usermanagementhelp", ulx.usermanagementhelp )
usermanagementhelp:defaultAccess( ULib.ACCESS_ALL )
usermanagementhelp:help( "See the user management help." )
Or
/lua/ulx/base.lua
local function sendAutocompletes( ply )
if ply:query( "ulx map" ) or ply:query( "ulx votemap2" ) then -- Only send if they have access to this.
ULib.clientRPC( ply, "ulx.populateClMaps", ulx.maps )
ULib.clientRPC( ply, "ulx.populateClGamemodes", ulx.gamemodes )
ULib.clientRPC( ply, "ulx.populateClVotemaps", ulx.votemaps )
ULib.clientRPC( ply, "ulx.populateKickReasons", ulx.common_kick_reasons )
hook.Add( ULib.HOOK_UCLAUTH, "sendAutoCompletes", sendAutocompletes )
hook.Add( "PlayerInitialSpawn", "sendAutoCompletes", sendAutocompletes )
-- This will load ULX client side
local function playerInit( ply )
local _, v, r = ulx.getVersion()
ULib.clientRPC( ply, "ulx.clInit", v, r )
hook.Add( "PlayerInitialSpawn", "ULXInitPlayer", playerInit )
Our ULib docs seems, to me, to explain it pretty well.
Treat any function as though it's run on client. Parameters passed get used.
Offline krooks
    • Diamond Krooks
Re: ULX User mysql
« Reply #14 on: March 06, 2013, 01:14:43 am »
Thank you JamminR for those snippets.
I spent about 2 hours messing with my code, trying to mimic those, but came up with nothing.
I wrote a long frustrated post, about how I don't think I'm cut out for this type of code, gave it a break, and started to mess with some other code, when I ran across a good SetNWInt / GetNWInt example.
And this is what I came up with:
server:
ply.donation = data[1]["donation"]
        ply:SetNWInt("donation", ply.donation )
client:
draw.SimpleText('Total donations: $' ..LocalPlayer():GetNWInt("donation"), 'PS_Heading3', self:GetWide() - 10, 0, color_white, TEXT_ALIGN_RIGHT, TEXT_ALIGN_BOTTOM)
and it worked! (and now it is WAY too late for a week night)
