Author Topic: How can i make it say " *this person* has joined the server"  (Read 8436 times)
Offline datgregofag
« on: January 21, 2013, 07:25:35 am »
Whenever i play on my server and i use ulx, it doesn't say anything in chat when someone joins my server. In evolve it says the persons name and when they last joined, is there any possible way to do that in ulx and if there is can someone help me do that. Thank you.
P.S Evolve is gay. ULX FOR DA WIN!!!
Offline datgregofag
Re: How can i make it say " *this person* has joined the server"
« Reply #1 on: January 21, 2013, 09:43:42 am »
also i think to make it say in chat you have to modify this
local function playerConnect( name, address, steamid )
   if logEvents:GetBool() then
      ulx.logString( string.format( "Client \"%s\" connected (%s).", name, address ) )
hook.Add( "PlayerConnect", "ULXLogConnect", playerConnect, -20 )
local function playerInitialSpawn( ply )
   local txt = string.format( "Client \"%s\" spawned in server (%s)<%s>.", ply:Nick(), not ply:IsBot() and ply:IPAddress() or "BOT", ply:SteamID() )
      ulx.logString( txt )
   if logJoinLeaveEcho:GetBool() then
      echoToAdmins( txt )
hook.Add( "PlayerInitialSpawn", "ULXLogInitialSpawn", playerInitialSpawn, -19 )
local function playerDisconnect( ply )
   local txt = string.format( "Dropped \"%s\" from server<%s>", ply:Nick(), ply:SteamID() )
      echoToAdmins( txt )
can you please modify this or whatever you need to modify, im lua noooooob, also i got this from \garrysmod\addons\ulx\lua\ulx\logs.lua
Offline krooks
  • I don't like video games.
    • Diamond Krooks
« Reply #2 on: January 21, 2013, 01:18:56 pm »
This is what I use, put it in garrysmod/lua/autorun/server/WhateverNameYouWant.lua
--Enter and Exit server
function FirstSpawn( ply )
    PrintMessage( HUD_PRINTTALK, ply:Nick().. "("..ply:SteamID()..") entered the game.")
hook.Add( "PlayerInitialSpawn", "playerInitialSpawn", FirstSpawn )
function PlayerDisconnect( ply )
    PrintMessage( HUD_PRINTTALK, ply:Nick().. "("..ply:SteamID()..") has disconnected." )
hook.Add( "PlayerDisconnected", "playerDisconnected", PlayerDisconnect )
This also shows steam id. Handy for banning people who do bad stuff then leave.
My TTT server. Join the fun!
Offline datgregofag
« Reply #3 on: January 21, 2013, 02:13:40 pm »
Thank you so much, i appreciate your kindness and generosity.
« Reply #4 on: January 21, 2013, 03:44:51 pm »
Though the steamid would indeed be an addition...does Gmod not already show people connecting in the chat text???
Did GM13 change that?
I remember back when I played regularly, changing maps, tons of '<X> joined>' would pop up after the level change.
Offline krooks
    • Diamond Krooks
« Reply #5 on: January 21, 2013, 06:21:13 pm »
I believe it was a ULX function, that no longer works? There's a place in xgui to turn it off and on, does nothing.
No prob datgregofag
Offline TweaK
    • Garry's Mod Engineers
« Reply #6 on: January 22, 2013, 12:28:51 am »
Figured I'd toss mine on here too.
local function onConnect( name, addr )
ULib.tsayColor( nil, false, Color(128, 255, 128), "Player " .. name .. " connected" )
hook.Add( "PlayerConnect", "doSayOnConnect", onConnect )
local function onInitialSpawn( ply )
for k, v in pairs( player.GetAll() ) do
if not ( v == ply ) then
ULib.tsay( v, "Player " .. ply:Nick() .. " has entered the game" )
hook.Add( "PlayerInitialSpawn", "doSayOnSpawn", onInitialSpawn )
local function onPlayerDisconnect( ply )
ULib.tsayColor( nil, false, Color(128, 255, 128), "Player " .. ply:Nick() .. " dropped from the game" )
hook.Add( "PlayerDisconnected", "doSayOnDisconnect", onPlayerDisconnect )
« Reply #7 on: January 22, 2013, 08:55:35 am »
It almost feels like this should be built into ULX (Didn't ULX have it already?) , maybe even some thing where you could make your own custom string.
Example...
%user% has joined from %country%
and you can also change it to
Welcome, %user% they are from %country%
or even
A %user% has connected!
Then throw in some convars like...
ulx_join_enabled 0/1 (To enable/disable showing when some one joined.)
ulx_join_showadmin 0/1/2 (If set to 0 admin names will be shown when they join, if set to 1 the join echo will be hidden when an admin joins, if set to 2 a fake name is shown instead of the admins name.)
I think that would be a good addition to ULX, don't you? Also if no one is going to make this I will :)
« Last Edit: January 22, 2013, 08:57:50 am by HeLLFox_15 »
Offline krooks
    • Diamond Krooks
« Reply #8 on: January 22, 2013, 12:48:51 pm »
Oo I like the idea of adding the country, Fox!
« Reply #9 on: January 22, 2013, 02:39:35 pm »
UTime has the functionality you're looking for. :)
