Author Topic: Ulx breaks after a few minutes.  (Read 4511 times)
Offline ryanb5111
« on: January 27, 2013, 07:36:12 am »
So when the server restarts everything works fine, chat commands work, etc... Then after a few minutes/hours the server glitches a bit and shows the hints again like you just joined the server and the chat commands dont work.... Is this a common problem or...
Re: Ulx breaks after a few minutes.
« Reply #1 on: January 27, 2013, 08:16:53 am »
Explain more please?
ULX doesn't have server hints when you join.
If you mean some gamemode hints, then, it sounds like you have deeper rooted issues, that then affect ULX.
When it 'glitches', I'd presume there would be server console errors at that point, and/or when trying to run ULX commands.
What error appears in server console when you try to run a command?
« Reply #2 on: January 27, 2013, 01:25:24 pm »
Sounds like you're running into this issue. We won't be fixing this in the immediate future, as it only breaks due to human action.
Offline bender180
    • Benders Villa
« Reply #3 on: January 27, 2013, 07:58:05 pm »
Well that explains why when i start my server the !commands work and then they stop out of nowhere.
