Author Topic: can we make clients reconect if the server crashes ?  (Read 7439 times)
Offline nathan736
« on: January 28, 2013, 09:07:30 pm »
if ( CLIENT ) then
function didwecrash()
if (not wedidcrashdamit) then
timer.stop( "didwecrash" )
timer.Destroy( "didwecrash" )
if (not timer.IsTimer("didwecrash")) then
wedidcrashdamit = true
timer.Create("didwecrash", 20, 1,function()
if (not wedidcrashdamit == nil) and wedidcrashdamit then
RunConsoleCommand("connect 50.31.65.166:27015")
end)
hook.Add("Think",didwecrash,wecrashed)
local function RecvMyUmsg( data )
wedidcrashdamit = data:ReadBool()
usermessage.Hook( "didwecrash", RecvMyUmsg );
if ( SERVER ) then
function sdidwecrash()
if (not timer.IsTimer("sendcrashinfop")) then
timer.Create("sendcrashinfop", 5, 0,function()
umsg.Start( "didwecrash" );
umsg.Bool( false );
umsg.End();
end)
hook.Add("Think",sdidwecrash,swecrashed)
my objective here is to make the client rejoin the server if the server crashes or lags big time
« Last Edit: January 28, 2013, 09:17:08 pm by nathan736 »
Re: can we make clients reconect if the server crashes ?
« Reply #1 on: January 28, 2013, 09:33:27 pm »
I might be wrong here.. but I think that clientside scriptings stop when the client disconnects.
I don't think this is possible.
Offline nathan736
« Reply #2 on: January 29, 2013, 08:30:09 am »
so the client disconnects if the server lags hard core... dam it  did garry change something i saw  a server do it in gmod 12 or something
« Reply #3 on: January 29, 2013, 09:09:38 am »
It might be possible, I'm not sure how you'd go about doing it, but it would have to be entirely client-side code. If the server crashes or gets severely lagged, it's not going to have any time to politely inform the clients that it crashed.
Offline nathan736
« Reply #4 on: January 29, 2013, 10:57:00 am »
if ( CLIENT ) then
print("||retry system loaded!||")
function didwecrash() -- client  auto ran crash checker
print("we should be rejoing now")
end)
timer.start("didwecrash")
timer.Create("didwecrash",20,1,function() -- creates a timer that restarts if true
end)
if ( SERVER ) then
timer.simple("sendcrashinfop", 10, 0,function()
umsg.Bool( false )
umsg.End()
end)
timer.start("sendcrashinfop")
this clearly does not work i think timers are synced with the server :/
« Last Edit: January 29, 2013, 03:35:00 pm by nathan736 »
« Reply #5 on: January 29, 2013, 04:47:37 pm »
99% sure of this;
Can you imagine the horrors of some not-so-nice server host causing you to do things once you connected to another server?
I can. *shiver*
Offline nathan736
« Reply #6 on: January 29, 2013, 08:03:24 pm »
EDIT : wowowo back up  the client disconnects if the server lags ? im confuzled
is think hook synced as well ?
« Last Edit: January 30, 2013, 08:37:39 am by nathan736 »
« Reply #7 on: January 30, 2013, 02:54:02 pm »
If a server lags for long enough, and the client's frame "keep alive" packets never get acknowledged from the server, yes, the client will disconnect.
I've not played GM13 enough to have seen it, but in GM<12 it was a little red text at top right of screen with something like 'connection issue: <and ip I think>'.
As for the think hook, i don't know if it's synced or not, but I would imagine some hooks are.
« Reply #8 on: January 30, 2013, 07:18:31 pm »
It's the same in GM13.
