Author Topic: A toggle to prevent people from spraying over other sprays.  (Read 5673 times)
« on: January 30, 2013, 09:52:46 pm »
I have always found it very annoying of how people just spray over a spray because they don't like how it looks or whatever.
There should also be a way for admins to remove a spray and stop people from using their spray.
I have not the slightest idea on how one would do this but I hope some one can at-least start making some thing to "fix" this.
Re: A toggle to prevent people from spraying over other sprays.
« Reply #1 on: February 02, 2013, 05:25:16 pm »
Also a way to put sprays on props would be awesome. :)
« Reply #2 on: March 23, 2013, 04:10:34 pm »
Running the following code on clients stops sprays altogether. You can make it more complicated as you see fit. There may be another way to do it from the server (which would be better), but I'm not certain.
  1. hook.Add( "PlayerBindPress", "t", function(player, bind)
  2.   if bind == "impulse 201" then
  3.     return true
  4.   end
  5. end )
  6.
