Author Topic: How do I make every command silent?  (Read 4689 times)
Offline Zevoxa
« on: February 03, 2013, 08:36:42 pm »
Is there a way to make every command silent (while using commands from xgui)? It would be greatly appreciated if that was possible.
Re: How do I make every command silent?
« Reply #1 on: February 03, 2013, 08:55:14 pm »
Set echo to 0.
Not exactly sure where to do that in xgui, but it can be done manually through gmod/data/ulx/config.txt (if there isn't one there, copy, then edit, one from gmod/addons/ulx/data/config.txt
All options there are commented well (including the one that says COPY it first, then edit) :)
Offline Zevoxa
« Reply #2 on: February 03, 2013, 09:02:11 pm »
A reply from one of the creators. Awesome, worked perfectly! :3
