Poll
Was any of these somewhat interesting or "cool"?
Yes, thank you :)
262 (96.7%)
No, do better next time :(
9 (3.3%)
Total Members Voted: 0
Author Topic: Player Connect/Disconnect Message [1.11v]  (Read 236809 times)
Offline Dawnkiller
  • FawX Gaming
    • FawX Gaming
Re: Player Connect/Disconnect message
« Reply #90 on: April 24, 2014, 03:49:35 am »
Is there any way of changing the volume of these pings? It near as damnit deafens people on mapchange when 20+ people connect at the same time.
Offline Neku
« Reply #91 on: April 24, 2014, 09:25:14 pm »
Just disable the sound.
Offline Bite That Apple
  • Apple Innovations 2010®
    • Fun 4 Everyone Gaming
« Reply #92 on: April 24, 2014, 11:20:53 pm »
Kinda made me chuckle.
« Reply #93 on: April 25, 2014, 07:47:33 pm »
May I strongly suggest you tell the person questioning... HOW!?
There is no config file,  No console commands,  No convars for this script. It's not a ULX specific menu addon. It's straight Lua.
Though, yes, you may find it easy and experience shows you how, imagine yourself as a 99.999% Lua newb.
And the only reason you've got the .001% experience is because you've seen the word "Lua".
How then would you consider your answer?
Offline Neku
« Reply #94 on: April 25, 2014, 10:12:30 pm »
Alrighty, go into one of the lua files in here. I don't know which one since it's literally been 6 months since I last used this.
Find the line of code with .wav or .mp3.
Type this in that same line before the code.
My best guess is that it's in the clientside lua.
Offline Dawnkiller
  • FawX Gaming
    • FawX Gaming
« Reply #95 on: April 28, 2014, 02:03:35 am »
I appreciate the sentiment JamminR, and understand the principle of helping out newer coders. Luckily, I'm not a complete coding newb, just fairly new to Lua. I'm aware I could just disable the sound by commenting it out but I like having the sound while the round is active, it does a good job of notifying people of joiners, and leavers especially.
I've considered two other options:
1. Remake the base ping sounds in Audacity or whatever to reduce the volume, reupload as a custom sound and change the file path in the Lua.
or
2. Could perhaps add a kind of timing loop/delay that disables the sounds in the first 10 seconds of the map starting? Is that possible?
EDIT:
Which part, the naivety that I could change the volume of a base file, or the deafening pings of death?  :P
« Last Edit: April 29, 2014, 02:46:07 am by Dawnkiller »
Offline Neku
« Reply #96 on: April 28, 2014, 02:55:37 pm »
Could you paste the code on that line for me?
Offline Dawnkiller
  • FawX Gaming
    • FawX Gaming
« Reply #97 on: April 29, 2014, 02:44:20 am »
surface.PlaySound( "garrysmod/save_load1.wav" )
Offline peterchamp00
« Reply #98 on: June 27, 2014, 07:33:31 am »
I just added this to my server and when I was spawning in the server I got a message in the top left of my screen that said "Something is creating script errors." I checked the console and it said Warning: Unhandled usermessage 'player_spawn'. How would I fix this error?
Offline Bob Dylan
« Reply #99 on: June 29, 2014, 04:11:23 am »
Hey chaos just want to thank you for this addon it has helped me so much and i am using the one that shows the steam id and it works perfectly just requesting though are you able to make a damagelog system for the gamemode jailbreak?
Offline Saucey
  • | OHQ Team | GCinema |
    • GCinema
« Reply #100 on: July 10, 2014, 10:17:30 am »
local Tags =
--Group    --Tag     --Color
{"admin", "ADMIN", Color(0, 0, 255, 255) },
{"superadmin", "SUPERADMIN", Color(255, 0, 0, 255) },
{"owner", "OWNER", Color(0, 255, 0, 255) }
How you did this code above, I would like for the connections to be displayed like so "[Server] [Admin] Mr. Apple has joined the server!"
I have 8 ranks that I would like to be displayed like how they display in the chat with that code.
I would greatly appreciate that!
« Last Edit: July 10, 2014, 10:20:27 am by hej »
Two possibilities exist...
Either we are alone in the universe or we are not.
Both are equally terrifying.
Offline nar308
« Reply #101 on: July 16, 2014, 03:55:10 pm »
Is there a way to only target a specific group only? So that that group is the only one that the notification comes up for. Thanks.
Offline Avoid
« Reply #102 on: July 16, 2014, 05:13:27 pm »
Hello,
take a look at the code and add something before the message is being shown to the players!
There you could do an if-statement with IsAdmin/IsUserGroup.
My 0.02$, Avoid
Offline nar308
« Reply #103 on: July 19, 2014, 12:13:56 am »
Thank you for the reply, so would it be something like
if (not IsValid(ply)) or ply:IsSuperAdmin()
then chat.AddText( Color( 255, 0, 255 ), "[Server] ", nickteamcolour1, name1, Color( 255, 255, 255 ), " has joined in the server." )?
Offline nar308
« Reply #104 on: July 31, 2014, 04:25:14 pm »
Ok a quick question again, how would i go about making it target a specific player. Like for example if i wanted it to only display the message to someone named Bob?
