Author Topic: Spawn script  (Read 7035 times)
Offline Deathtitan77
Spawn script
« on: February 11, 2013, 07:21:27 am »
Alright, so I am making a jailbreak gamemode. I am having a problem though, I can't get my spawn script to work. I would appreciate any help.
GM.Name = "Jailbreak"
GM.Author = ""
GM.Email = ""
GM.Website = ""
warden = ""
function GM:Initialize()
self.BaseClass.Initialize( self )
function GM:CreateTeams()
team.SetUp( 1, "Guards"    , Color(0  ,0,255), false)
team.SetSpawnPoint( 1, "info_player_counterterrorist" )
team.SetUp( 2, "Prisoners" , Color(255,0,0  ), false)
team.SetSpawnPoint( 2, "info_player_terrorist" )
Offline nathan736
Re: Spawn script
« Reply #1 on: February 11, 2013, 10:55:38 am »
give us full code this is not the spawn system this is just the back bone team system
PS: MOVE THIS TO DEV AREA
PSS: use the code brackets or use ideone for reading >: )
« Last Edit: February 11, 2013, 11:27:20 am by nathan736 »
Offline Bite That Apple
  • Apple Innovations 2010®
    • Fun 4 Everyone Gaming
Re: Spawn script
« Reply #2 on: February 12, 2013, 01:15:34 am »
Who is us?
Re: Spawn script
« Reply #3 on: February 12, 2013, 04:38:58 am »
Well, this is my code. This is my whole spawn code.
Re: Spawn script
« Reply #4 on: February 12, 2013, 08:07:15 am »
Are there any console errors? If there are no errors, are you making sure to play the gamemode on a counter strike map or a map you made using counter strike as your mod in SDK Hammer?
Offline nathan736
Re: Spawn script
« Reply #5 on: February 12, 2013, 08:22:59 am »
EDIT
this is not spawn code  by the way, this is how you set up the teams theres your problem click the link at the bottom \/ for info about teams
spawn code im sure does not work if you are not on a team (i don't think you get set to a team auto so you need a spectator and or dead team#)
ps : also you don't need to define warden as "" in game int or wherever you doing this (does not hurt tho)
pss: this might help some but might be old
Quote from: http://maurits.tv/data/garrysmod/wiki/wiki.garrysmod.com/index6665.html
You need to set the team up on both the client and the server. This would ideally be achieved by defining your team-setup's in your gamemode's shared file.
psss: might want to make sure you have your team set up you kind of did not give me everything so >: (
http://maurits.tv/data/garrysmod/wiki/wiki.garrysmod.com/index75fb.html
« Last Edit: February 12, 2013, 08:36:00 am by nathan736 »
