Author Topic: Death Messages (ULX Module)  (Read 6996 times)
Offline Mindless
« on: February 12, 2013, 03:50:09 pm »
Right basically i'm requesting a death messages script that prints to admin chat however you can toggle it by using ulx_togdm (toggle death messages).
Basically what this script does is example:
(BOT) Siri; <name> has killed <name> with weapon name.
(BOT) Siri: <name has overdose on heroin. (DurgZ mod).
in Admin chat if possible.
Offline Bite That Apple
  • Apple Innovations 2010®
    • Fun 4 Everyone Gaming
Re: Death Messages (ULX Module)
« Reply #1 on: February 12, 2013, 04:00:45 pm »
this script would get mighty annoying to the admins I feel.. Unfortunately, I don't understand stand how ulx custom commands work (I know it's not that hard, I just haven't cared enough to do so) but now that this has come up, I'm curious if I could do it. Anyone else can work on this too, I just kinda want to work on this as a side project.
Also, I think you can just press the Console key "~" (default) and open up the console menu to look at who killed who using what.
« Reply #2 on: February 12, 2013, 07:24:28 pm »
Good place to start -
/index.php/topic,4464.0.html#msg17838
Mostly, check out the line mid way through first post starting with [NEW STUFF HERE]
Then, you could also check out all the ULib functions that ULX uses for command set up here - http://www.ulyssesmod.net/docs
Offline nathan736
« Reply #3 on: February 13, 2013, 08:07:26 am »
i can probably take a gander at this some time when i finish stuff im working on (i currently see my self as notorious as not finishing things)
Offline Mindless
« Reply #4 on: April 04, 2013, 02:00:00 pm »
Just asking is there a way to send who kills who to admins?
« Reply #5 on: April 05, 2013, 02:04:16 pm »
« Last Edit: April 06, 2013, 02:07:39 pm by HeLLFox_15 »
