Author Topic: Is this safe?  (Read 7405 times)
Offline PAL-18
Is this safe?
« on: March 07, 2013, 10:03:30 pm »
I just noticed the following on the Gmod forums and i was wondering if it was a ripoff of Ubans and if not, is it safe to use (not virus'd up):
http://facepunch.com/showthread.php?t=1231554
« Last Edit: March 15, 2013, 04:49:30 pm by PAL-18 »
Re: Just noticed a possible rip off on gmod forums ...
« Reply #2 on: March 08, 2013, 02:52:32 pm »
The one linked in the original post doesn't use a public system. It only uses servers connected to the database that you have to set up yourself. I am not familiar with UBan but it seems that this one is just a little more feature filled.
Offline PAL-18
« Reply #3 on: March 10, 2013, 12:53:43 am »
Ah ok, just wanted to make sure.  The guy has a really low post count on the gmod forums and i dont generally trust people with low post counts (unless they have an official role) when they release something.
« Reply #4 on: March 10, 2013, 05:53:03 pm »
I can understand that, but it isn't always the case.
For instance, I have been a member on Facepunch since 2005 or so and my post count is under 30 or so. I only post on facepunch when I have a release or a reply to a question in a release thread I created. I don't typically lurk on Facepunch.
Join Date
    20th July 2005
Last Activity
    1 Minute Ago
Total Posts
    3
« Last Edit: March 11, 2013, 12:15:51 am by MrPresident »
« Reply #5 on: March 10, 2013, 08:32:58 pm »
Indeed.
For me
Quote from: JamminR's Facepunch Profile
Join Date
    14th April 2005
Total Posts
    159
I wouldn't even consider what I do 'lurking'.
"Avoid when possible" now maybe?
Before I joined Team Ulysses, I lurked there.
When I joined Team Ulysses, I participated there.
Once I realized just how crazy some of the admins, if not the people that actively participate there are, I visit only when necessary.
Kind of like when I viewed the above linked post.
I know Stick and Meg make our releases there too, and I should probably help.
I don't, because I hope the users of our product are intelligent enough to come here instead.
Offline PAL-18
« Reply #6 on: March 11, 2013, 04:47:49 pm »
You're both on the ULX team though, so that makes up for a lot.
« Reply #7 on: March 11, 2013, 05:45:31 pm »
Right, but it's just as an example. You can't judge based solely by post count. :)
Offline nathan736
« Reply #8 on: March 15, 2013, 06:16:22 am »
you can judge based on post count but you should use this information to investigate  ;D
« Reply #9 on: March 15, 2013, 09:32:30 am »
Between receiving two permabans and the general stupidity of FP'ers, I try to avoid it as much as possible as well.
Thanks for the report, even though it's legitimate in this case.
